Model: Classic Mini 30year Limited Edition
Year: 1989
Description of problem (please be as in depth as possible): We have recently put together our mini after having the engine out and all the dashboard for a respray, we have put most of it together (well the engine is in, most of the wires are all connected except the headlights and radio). The indicators/hazardlights work with or without ignition turned on, but for some reason the dashboard has two lights permanently ON even when the keys are not in the ignition.
The coil is also getting VERY hot! so we have to keep it disconnected. Can anyone suggest what might be wrong? do you need anymore info?
I have also tried un-pluging the Coil and/or Alternator, but again at least one light stays on Orange but when I plug the connector onto the alternator both lights are ON. I have checked and rechecked the wiring and it all looks OK, there are no exposed wires touching the body and the body/engine are EARTHED.
Can anyone suggest what else I need to check/do?
Any non-standard parts that might be involved with the problem? - The only non-standard part we fitted that was NOT part of the original setup was a foglamp cable that moves it into the rear light assembly, i.e. no more dangling fog lamp on the valance.
Edited by LeosMini, 22 June 2009 - 09:53 PM.
