Classic Mini Tow Bar
20 replies to this topic
#16 MRA
MRA
  • 7,607 posts
Posted 02 July 2009 - 08:12 PM
Is there a homologated tow bar prior to 1998 ?
I've seen loads of non CE marked towbars fitted to cars... especially Minis is there a date when this was not required ?
Regards Martin
#17 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 02 July 2009 - 08:17 PM
Prior to August 1998, homologation was not required and anyone could make a towbar for anything.
#18 MRA
MRA
  • 7,607 posts
Posted 02 July 2009 - 08:34 PM
That explains that then :thumbsup:
#19 ned320
ned320
    Just On Tickover
  • 8 posts
Posted 08 July 2009 - 03:54 PM
thanks for all your help. so pulling a trailer with my mini is a no no then boooo hoooo
looks like i'll have buy another mini ( my misses with nack me )
#20 bmcecosse
bmcecosse
  • 9,699 posts
Posted 08 July 2009 - 04:28 PM
Be wary of using the boot floor for tow-bar attachment - it has no real strength even when new - and even less now! I had a tow bar - home made - that attached entirely to the rear subframe - much more solid and reliable - used it to tow my racing Mini on a trailer. Even then - obviously the subframe mounts to the shell must be in good condition ! If you two anything with a post 98 Mini - you will likely not be insured.
Is there not now also a requirement to pass a special test to tow anything now - unless you have an 'older' licence ?
#21 chunkytfg
chunkytfg
  • 116 posts
Posted 08 July 2009 - 05:03 PM
Technically yes if you passed your driving test after aug 1997 you only have the B catagory on your licence and not the B+E required to tow anything. However the B catagory allows you to tow anything up to 750kg's max gross weight in an unbraked trailer with a vehicle up to 3.5t and any braked trailer providing the Laden weight of the trailer does not exceed the unladen weight of the towing vehicle and the combined MAX GROSS WEIGHT does not exceed 3.5t.
In a mini towing a trailer having only B on your license should not be a worry as i would doubt your trailer will exceed 750kgs
