First Car- A Blue Project Mini!
#16
Posted 21 June 2009 - 01:32 PM
#17
Posted 21 June 2009 - 01:39 PM
#18
Posted 21 June 2009 - 05:41 PM
I used rustoleum paint, very similar to hamerite
you can use hammerite without a primer as long as your going direct to a rough but sound surface (ie direct to rust)
but like mini sam said, I'd neutralize the rust first with something like jenolite, or even better hydrate 80.
great progress so far.
#19
Posted 30 June 2009 - 09:27 PM
ouch fourth page! i havent done much untill recently.
so today me my mate matt my dad (his angle grinder) and my little brother started to remove things from the shell, starting with the doors...
so from :
to:
and the doors:
they aren't to rusty the skins look fine even at the bottom, bit orange inside and some small paint bubbling though
so having done that and having daylight left we cracked on with removing the scrap front panel and passenger wing (the black drivers side wing and bonnet in earlier images were just balanced on as there was nowhere for them to be stored)
so after the surgery:
the wing and front panel were ground off and i drilled out the spotwelds on the small section of remaining wing lip
after that we continued to remove inside-type stuff like soundproofing and steering columns and all that manky foam stuff inside the dashboard:
(matt spent half an hour undoing one stubborn bolt on the bottom of the steering column he was dissapionted when it did not simply slide out! later it turned out it just needed more 'persuasion' to be removed and he hadent wasted his time
after that and after some blokes in a van thought i was breaking the car (
so the mini is not far from a bare shell now nearly ready for welding!!
#20
Posted 30 June 2009 - 09:52 PM
Good luck with your project. looks awesome for the money. your working really quick.
#21
Posted 30 June 2009 - 10:14 PM
Edited by tomgale, 30 June 2009 - 10:15 PM.
#22
Posted 02 July 2009 - 09:39 PM
stripping the subframes today, everything's off no pics because its not very interesting front seems fine and is still black in places but the rear is flakey and has holes so its of to the scrappy with the front panel and wings. the heater matrix and gear change has also been removed from the car.
tom
#23
Posted 03 July 2009 - 10:38 PM
today we cleaned the spare rear subframe and painted it. this is the one which will be used on the car as the one we removed was scrap
so before:
after being attacked by a wire wheel-equiped angle grinder(part of which broke off and became embedded in my arm it looked cool!
my not serious but cool lookin injury:
and with one coat of black hammerite
will probably do more coats over the weekend
tom.
#24
Posted 08 September 2009 - 09:25 PM
ok i know i havent posted for a while but ive been in america for a month and then ive had loads of course work.
but: i have managed to finish stripping it, loom is out and everything. (no pics but im sure you know what a naked mini looks like
rear valance has holes
boot floor is full of holes (i have a repair panel for this now so can fix it)
under the rear bench where the subframe mounts- large hole on both sides into the door bins
sills have holes, drivers side has an oversill
drivers door step has a big hole in the middle
both footwells have holes and need attention ( pasengers side has a replacment panel on top of the rot held in place by wood screws to be welded by a previous owner)
drivers side fresh air vent has been badly repaired at some point
front bulkhead has many holes of various sizes
a-panels need to be welded on
drivers side inner wing is a bit dodgy (the lip on the top looks hand beaten)
wings and front panel need to be welded on
getting a welder soon so going to have a go at the weekend, never done it before so could be interesting...
#25
Posted 08 September 2009 - 10:02 PM
How are you gonna go about the bodywork? front to back, back to front?
#26
Posted 09 September 2009 - 06:09 AM
im probably going to go back to front as the only panel i have is the boot repair and the front end, and ive got to sort the inner wing before it goes on.
#27
Posted 20 September 2009 - 08:34 PM
didnt go well, kept blowing through and making holes
so, this weekend we swapped the wire to 0.6 (from 0.8) and practiced on an oversill that came with the car:
this went better! shocked how much of a difference this makes, really cheered us up as the whole project depends on us being able to weld.
so at uttoxeter the other weekend i bought a boot repair panel, we started to cut out the rotty section at the back of the boot for the panel only to discover that the rear valance closing plates and lower parts of the wheel arch were rusted through so after we cut everything out we were left with:
so today we cut the repair panel to fit and used the leftover metal to patch the arches:
clamped in:
and seam welded in from both sides:
will flap disk it and do some more welding next weekend (unless ben wants his welder back)
#28
Posted 20 September 2009 - 08:52 PM
Worked for me!!
Regards
Steve
#29
Posted 20 September 2009 - 09:00 PM
tom
#30
Posted 27 September 2009 - 08:44 PM
so, finished patching the wheelarch and flap disc'd it:
and then degreased and given a few layers of etch primer:
had to be careful not to upset the new dog, 7 week old cocker spaniel *woman of ill repute* edit:(that was supposed to be 'lady dog' the forum wont let me say the 'b' word even in the correct and legitimate context
thats all for now, tom.
Edited by tomgale, 27 September 2009 - 08:47 PM.
