First Car- A Blue Project Mini!
Posted 18 June 2009 - 10:10 PM
on the trailler
this afternoon i got it out and emptied all of the parts out of it- it was filled to the roof with things, the boot was overflowing too.
before i cleared it
and after:
i made a little mess......
oh well the mini's empty at least. was able to see what condition the body work was in: not that bad considering i only paid £255 for it. Needs: new wings and front panel but these came with the car, sills are a tad rusty nothing catastropic (famous last words), few small holes in the floor pan and drivers side doorstep has a big hole in the middle.
getting everything out of the back meant that i could see what i have and the list is:
1x 998 engine
1x back bench
3x front seats (1 recliner 2 normal)
4x front lights
4x rear lights
2x bootlids (one with tastefull brush painted hammerite red stripe down the middle!)
1x set of door cards
3x rear screen
2x front screen
4x rear side windows
2x heater matrix
2x interior trim (handles etc)
2x steering column
2x steering wheel (not sure which i prefer yet)
2x front subframe
2x rear subframe
8x wheels (6 10 inch 2 12 inch)
1x replacement front panel
2x replacement wings
1x replacment grill
and assorted other bits and bobs (some of which are shiney )
then i tucked it away back in its garage, its very small only half length so the mini just fits inside.
if i get coursework finished early the mini will get some more attention over the weekend.
finally added an essential component:
fluffy dice!!!
Posted 19 June 2009 - 12:12 AM
I think 10 inch wheels low as can go and retro would look sweet, best of luck with it.
Posted 19 June 2009 - 12:18 AM
Looks like a great base for a project. sweet buy for £255
What are the plans for her? and which bit's are you doing yourself?
Have fun
*edit* dam you cookie
Edited by deemo, 19 June 2009 - 12:35 AM.
Posted 19 June 2009 - 06:18 AM
hey cookie- i want to paint it red with black roof and arches the current paint isn't great will try tto find a mk 1 grill -wide 10 inch wheels but il have to sort the brakes, got metro disks at the minuite
hi deemo was going to do most of it myself but never done anything like this before, so it could be a slow process
Posted 19 June 2009 - 10:05 PM
thought i'd share with you this afternoons mini based activities.. stripping the spare rear subframe! it needed doing as i couldnt fit it in the garage in one peice.
so.. before:
one radius arm off
i sheared my first bolt!!
and fully stripped at the end:
i know its not the biggest achivment in the world, but its the first real 'dirty' job ive done, loved it!
it dosent look that different but ive got a bowl of nuts and several bags of mounts stored away for further use now.
removed all the spiders living in the brake hoses and the strange larvea thing which was hidden in the muck which has accumulated over time.
by the way i saw an orange mini drive past me as i was doing the subframe, any one on here?
Posted 19 June 2009 - 10:07 PM
Posted 19 June 2009 - 10:13 PM
Posted 20 June 2009 - 11:06 PM
removed front and rear subbys and placed shell on to a wooden frame with castors in the corner .
so from this:
to this:
sorry i forgot to take pictures as we were doing it, but heres one of the stuff we removed:
im quite pleased came off with a little bit of persuasion (grinder) but the subframes are intact, the rear looks a bit flaky though
Posted 21 June 2009 - 12:13 AM
Posted 21 June 2009 - 07:53 AM
also, does anyone know which paint is best to repaint the subframes? thanks!
Edited by tomgale, 21 June 2009 - 08:06 AM.
Posted 21 June 2009 - 08:40 AM
Posted 21 June 2009 - 09:34 AM
Posted 21 June 2009 - 09:43 AM
sorry to hijack abit, about to paint my subby's with hammerite but wasnt sure if i needed to use a primer on them? or can i just paint it on? also do i need smooth hammerite or the other stuff?
Thanks!
Posted 21 June 2009 - 09:47 AM
Posted 21 June 2009 - 10:29 AM
