Read Alot Into Supercharing But Need More Information
89 replies to this topic
#61 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 22 June 2009 - 04:44 PM
does vmax have a online shop or do i need to buy it over the phone?
Just had an email back from Stuart at Vmax, and he said small items can be paied for by PayPal, and all prices include Postage. All you have to do is send the money by PayPal, and in the comments bit, put what you want, and where you want it sent to. If you want their PayPal address its: [email protected]
#62 blister
blister
  • 1,008 posts
Posted 22 June 2009 - 07:16 PM
so should i buy anything else that i sed from earlier?
#63 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 22 June 2009 - 07:29 PM
Is that what 998city said?
#64 blister
blister
  • 1,008 posts
Posted 22 June 2009 - 08:38 PM
sorry yeah i have read this whole thread way to much shall i buy everythin he is getting bit confused cause we are after the same thing
#65 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 22 June 2009 - 09:21 PM
steady bracket £10 (Not needed, but I might be getting one)
supercharger gaskets (2) inlet and charger case £15 (Needed!)
reinforced manifold gasket £12 (I don't think these are needed, a normal one might do?)
longer throttle and choke cables £7 / £7 (Both needed!)
carb needle and seat (fitted to item obove ) £30 (Not needed, get it set up on a rolling road)
thermostat low temp £4 (Not sure if one is needed?)
#66 blister
blister
  • 1,008 posts
Posted 23 June 2009 - 03:00 PM
i will be selling bottom pulleys that are exact replicas as all the usual ones and also can do custom sizes for 998s to lower the charger down will be gettin a few qoutes etc later on today if anyone is interested pm me .
i am going to order my stuff from vmax later on today and the charger will be up on the rollers later on just been round my local mini place and they rebuilt a innocenti and it was written off 20 minutes after it was driverable >_< its in a state
#67 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 23 June 2009 - 08:48 PM
How do you work out the custom sizes for the 998 bottom pulleys?
#68 blister
blister
  • 1,008 posts
Posted 24 June 2009 - 04:30 PM
did you not just sell one that you bought and was for a 998 why did you sell it?
#69 1275 SPRITE
1275 SPRITE
  • 1,188 posts
Posted 24 June 2009 - 06:50 PM
He sold it as he needs one with a built in trigger wheel because he will running megajolt as he said in his earlier post. The 998 and 1275 bottom pulleys are the same size.
#70 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 24 June 2009 - 08:51 PM
It is the pully on the charger you change the size of according to what set you have.
#71 blister
blister
  • 1,008 posts
Posted 24 June 2009 - 09:33 PM
oh ok where do you get a larger supercharger pulley then is it neccasery?
#72 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 25 June 2009 - 05:45 PM
That is what I'm trying to find out at the moment.
#73 smj
smj
  • 246 posts
Posted 01 July 2009 - 08:56 PM
hi, just read the whole of this thread, did anyone ever say what size top pulley was required to slow the charger down to work well with 998 engine, i am personally building a plus 20thou overbored 1098cc engine to supercharge, my compression ratio is below 8:1 without decompression plate, how or where do i found out how to calculate what boost the engine will be running????, and how do i alter or control the boost??? aldon are quoting for a distributor for me with custom advance, but i can't give them the info as to how much boost i will be running, as i don't have a clue how to calculate it!!!!
#74 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 01 July 2009 - 09:01 PM
no one uses a differant pully for 998
its its the same one as the 1275 in all the kits sold and they dont change the supercharger pully either
#75 smj
smj
  • 246 posts
Posted 01 July 2009 - 09:06 PM
so what boost does a straight from the box kit run???? how is it calculated???
