To work out the size of the pulley you need to first decide what bhp you are aiming for then calculate what airflow you'll need to achieve this. The psi will then be dictated by the airflow and the cc of the engine.
Once you know the airflow needed you can find out at what rpm the M45 will deliver the required flow (by reading of the flow map). It should then be easy to calculate what size pulley will give the required speed
Thanks for that Wil.
I think I am going to work out the required pully needed, then see if I can get one made up, I might know a company that will do it
