Read Alot Into Supercharing But Need More Information
89 replies to this topic
#1 998city
998city
  • 28 posts
Posted 16 June 2009 - 08:10 PM
i am not interested at all in buying a supercharger kit from jonspeed as i dont want to travel back and forth to have it set up i would prefer to build a kit myself and have a local mini friendly dyno sort the car out once i DIY my own kit.
i have bought a eaton m45 from a bmw mini it has down really low mileage and i am now after the manifolds a hif44 carb and i would like to know do i need the metro turbo carb as i dont want to be running blow through i would prefer suck and keep everything basic and neat.
also am i right in thinking that to complete my kit i need
supercharger manifold,
carb manifold
hif44 carb
airfilter
longer choke and throttle cables
belt
belt tensioner
and the bottom pulley
also what size bottom pulley do i need. as i was told this is highly influenced as i am running it with a 998
could anyone also tell my compression ration? its a standard 998cc City engine but with a stage one fitted
thank you
#2 998city
998city
  • 28 posts
Posted 16 June 2009 - 09:19 PM
anyone?
#3 1987_ParkLane
1987_ParkLane
  • 2,671 posts
  • Local Club: The Mini Forum
Posted 16 June 2009 - 09:38 PM
I have an Eaton 45 kit and here is what I got with my kit:
I did some measurements for people HERE
Also I think mini_mad_daps is making his own manifolds, so he might be worth a contact. Hope that helps a little :dontgetit: .
#4 998city
998city
  • 28 posts
Posted 16 June 2009 - 09:52 PM
do i need a certain size crank pulley for the conversion?
#5 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 17 June 2009 - 06:42 AM
Yes, you'll need to slow the charger right down if using it on a 998 compared to a 1275.
#6 blister
blister
  • 1,008 posts
Posted 17 June 2009 - 07:29 AM
well would it be best to increase the top pulley size or the bottom also do i need to do this because it would be making to much psi?
what sort of compression should i be aiming at? same as a turbo?
#7 mattwho?
mattwho?
  • 844 posts
Posted 17 June 2009 - 02:52 PM
im likeing this thred as i was thinking the same doing it diy
how much u think it cost not including rr to do this?
#8 998city
998city
  • 28 posts
Posted 17 June 2009 - 04:06 PM
yeah i was working it out that it should not be that expensive to do yourself
supercharger manifold and
carb manifold £250
hif44 carb £20
airfilter £20
longer choke and throttle cables £14
belt £10
belt tensioner £60
decommpression plate £40-100 or if you want dished pistons you will be adding alot of costs
prices are really second hand or from garages the £60 for tensioner is vmax anyone no cheaper?
#9 mattwho?
mattwho?
  • 844 posts
Posted 17 June 2009 - 04:17 PM
what about the charger what do they got for 2nd hand?
#10 998city
998city
  • 28 posts
Posted 17 June 2009 - 04:18 PM
well i was lukcy to get mine for £130 missed the parcel today though so i havent been able to inspect it
#11 998city
998city
  • 28 posts
Posted 17 June 2009 - 04:19 PM
they range from 130-250 i have seen on ebay
#12 mattwho?
mattwho?
  • 844 posts
Posted 17 June 2009 - 04:22 PM
so we saying like £500 for all parts?
they you have to rr it but does that take long as thats like £60+ an hour
#13 998city
998city
  • 28 posts
Posted 17 June 2009 - 04:24 PM
i aint including gaskets and RR oh and fuel pumps and regulators someone will be along shortly adding or taking away things i have said but i am just going by what i have been told
there are also probly other things like engine steady's and i dont know if it is necessary to upgrade cooling
#14 1987_ParkLane
1987_ParkLane
  • 2,671 posts
Posted 17 June 2009 - 05:32 PM
Are you talking about a 998? If you are, the bottom pully should really stay the same, and you should also really increase the size of the top pully so it doesn't spin as fast.
On mine I'm aiming for 8.5 - 9 CR at about 8psi.
I also got my supercharger kit for £875 brand new :ermm: .
#15 998city
998city
  • 28 posts
Posted 17 June 2009 - 06:15 PM
oh so it is ok to buy the usual size bottom pulley and use a larger one for the top? what is the reason of slowing down the blower?
also where do i get larger diameter supercharger pulleys
