Views On Seam Sealer ?
Posted 14 June 2009 - 04:58 PM
all coments welcome
Posted 14 June 2009 - 05:15 PM
Posted 14 June 2009 - 05:20 PM
thanks for the reply pete, when you seam sealered for example the outer seam from doorstep to outer sill did you just put seam sealer in the gap on the adge or paint it above below and in the gap?I have painted all my welds with two good coats of zinc primer then seam sealered over the top.Making sure that there is no rust to start with.Hope this helps.
hope that makes sence!
Posted 15 June 2009 - 12:14 PM
steer clear from upol grey stripe seam sealer, i used it before and as minipete did i sprayed on a zinc primer before appying seam sealer, the sealer reacted with the primer and cracked..........
i use dinitrol seam sealer instead, it costs a little more but it doesnt react with primer of paint...
steven
Posted 15 June 2009 - 12:29 PM
Posted 15 June 2009 - 09:22 PM
oh yes there is it celly based and absolute toshnothing wrong with upol seam sealer. make sure its fully dried before covering with primer.
Posted 16 June 2009 - 12:56 PM
You are clearly doing something wrong.
I've painted Upol seam sealer of Zinc primer and not had any problems atall. and ive also painted of the seam sealer with other various paints on different parts of the car with no problems atall.
Chris
Edited by Burnard, 16 June 2009 - 12:56 PM.
Posted 16 June 2009 - 06:58 PM
Posted 16 June 2009 - 07:11 PM
I put seam sealer in a mk1 Kadett, must be 15 years ago. Its still got the same paint job, and the sealer has'nt cracked.
Jas
Posted 16 June 2009 - 07:18 PM
wow thats reassuring, thanksI thought I'd replied to this, but I must have pressed the wrong key......
Jas
Posted 07 July 2009 - 07:01 PM
have you had this happen and is there anything to maybe thin it slightly?
thanks
Posted 07 July 2009 - 07:05 PM
We buy stuff in a tube, cant remember its name. Fits in a gun and with a pin hole in the end, its brilliant for finishing the seams around the front bumper lip where it means the front panel, scuttle corners and such.
Paint supplies will give better products/advice then halfords and the usual motor factors.
Jordie
Posted 07 July 2009 - 07:16 PM
i had the u-pol stuff from halfords, rather than brushing it on i used an old credit card or similar spread it up the weld lip, only a very small amount i might add and it makes it look much better and just seals those little holes i miss with the hobby welder
Posted 07 July 2009 - 07:19 PM
Posted 07 July 2009 - 07:29 PM
A local fella to me brazed all the gaps on his car.
