Compressors
10 replies to this topic
#1 Boots
Boots
  • 151 posts
  • Local Club: North Devon Mini Club
Posted 12 September 2005 - 09:41 AM
Hey there guys!
Im looking to buy a compressor, the main use would be for air power tools and spraying!
i dont want to spend hundreds, i was hopin for something around the mark of £250, can any one recomend any, or at least what i should look for ina compressor, for use of what i said? :grin:
Any help appreciated :lol:
Cheers Steve
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 September 2005 - 09:56 AM
If you're spraying then nothing less than a 50ltr tank, which is good for panels / doors etc... but whole car your realy need to be looking bigger... also cfm wise I'd say 8 and above...
If your considering grit/sand blasting, then double the above..
I have one of these, Machinemart clickylinkand it's great for things like impact wrenches, and not bad for spraying, but you do have to wait every so often for it to re-charge..
#3 Dog
Dog
    Deathwish Fairy
  • 9,550 posts
  • Local Club: Shatrats.com
Posted 12 September 2005 - 10:39 AM
GW...
Would that sort of size be ok to do underside spraying... i.e. hammerite?
#4 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
  • Local Club: Blacktop Bombers
Posted 12 September 2005 - 04:44 PM
As GW says, 8cfm or above. Also something else to bear in mind is that direct drive give more power, but get hot were as belt drive give slightly less power but don't suffer from the heat transfer as it has no drive shaft.
#5 miniman.matt
miniman.matt
  • 495 posts
Posted 12 September 2005 - 05:03 PM
you should not spray with a compressor that is any less than 100PSI. Although it does depend on what gun you use. I havnt used gravity feed guns before so am not sure what sort of PSI you will need to pull the paint out the gun. :lol:
#6 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
Posted 12 September 2005 - 05:17 PM
What about HVLP guns though
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 12 September 2005 - 07:09 PM
ÐØGMÁTÌX, I use my to shutz/stonechip the bottom of cars no problems... infact also used it to do my fence...
Load old shutz cannister with fence paint and point, a fence panel takes about 10 seconds :grin: tip of the week :cheese:
#8 Boots
Boots
  • 151 posts
Posted 12 September 2005 - 08:47 PM
Hey guys,
Thanks for youyr help so far! :lol:
Still trying to find the right one, although i seem to keep getting drawn to this one:
linky
what do u guys think, for my needs? :erm:
Steve
#9 Vash
Vash
    Just On Tickover
  • 8 posts
Posted 13 September 2005 - 04:42 AM
How about this one, apart from the 7.6cfm, Machine Mart are a rip off imo. http://www.screwfix....=86251&id=73259
#10 pickmeup
pickmeup
  • 174 posts
  • Local Club: West Country Minis
Posted 13 September 2005 - 11:28 AM
For HVLP you need to be looking at between 12-14CFM
However if you want to get that big a compressor you are looking at the 3 Horsepower ones which need to be hardwired on a 40amp supply like you cooker.
Im currently trying to find a 2.5Hp compressor which can do about 12CFM as you can still use them on a normal 13Amp supply!
#11 Prawn
Prawn
  • 938 posts
Posted 13 September 2005 - 09:15 PM
ive got a compressor steve, its 16cfm, and has a 150 litre tank!
only problem was wiring! ive still not got a supply, and its curently running with a 35amp mini fuse and no cover on teh plug!!!! highly unsafe i know.... but it was used like that to spray my whole car! when we get teh garage fitted out we will get a proper feed for it!
dont get a cheap oen for teh sake of having one steve.... its just not worth it!
