Engine cuts out
4 replies to this topic
#1 Neon trifle
Neon trifle
  • 77 posts
Posted 11 September 2005 - 08:28 PM
Hi
My P reg MPI Mini with only 1600 miles on the clock has been giving me a bit of bother lately. It starts perfectly every time but often cuts out within seconds. Also when driving along and taking my foot off the Gas to slow down for a junction it often just cuts out as well. When stopped in in trafic I am constantly anxious that its going to cut out just before the lights changed and obviously I am worried about a rear end shunt. The car is well serviced, I recently changed plugs.oil and air filter and leads look clean. What could this problem be........no Rover dealers in my areas and I would imagine I would have to go to them for the electronic diagnostic test?
Its getting so I dont want to go out in it because it drives so Rubbish.
Thanks in advance
Paul
Edited by minicooperman, 11 September 2005 - 08:50 PM.
#2 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 11 September 2005 - 11:37 PM
The car may be suffering from two faults rather than one. One or the other may not be as noticeble but the two together may cause the engine to stall at idle
The two most common faults on injection engines as follows
Check ALL vacuum lines especialy the thin black ones for splits and tightness, the ends of these are prime suspect as the split very easily and if the car is of decent age then they may be worth changing anyway. When was the last time the oxygen sensor was changed, if it wasn't recently then change it to. These are suposed to be changed every 30 thousand miles or two years and more often than not get overlooked, they only cost about £30 for a universal one rather than the £80 for the OEM ones.
Has the fuel filter been replaced?
#3 Neon trifle
Neon trifle
  • 77 posts
Posted 20 September 2005 - 03:28 PM
Hi
Thanks for the tip, I changed the fuel filter and the mini now runing perfect......in fact better than ever, I have not had it long and must have had a fuel filter problem all the time I have had it.....feels like a new car
many thanks
Neon
#4 Sprocket
Sprocket
  • 7,266 posts
Posted 20 September 2005 - 05:10 PM
Car fixed in one post. Now thats dam good. :)
Glad to be of some use, though the wife doesn't think so :nugget:
#5 AlexM
AlexM
  • 1,302 posts
  • Local Club: NMOC, ECMC
Posted 20 September 2005 - 07:01 PM
Isn't it great when a problem is so easily solved :grin:
