Carb To Injection Supercharged
32 replies to this topic
#16 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 26 July 2009 - 08:47 AM
Stig, Slightly OT, quite bizarrely was just looking at the 36-1 on trigger-wheels, once fitted do you have to space the fan pulley out by the same thickness to keep them in-line? Assuming that's what you've used?
Alan...
hi alan
the bottom pully is the standard one that comes witht the supercharger kits have just had it machined on the rear face to mount 36-1 trigger wheel to it
it runs the fan belt in the normal postion nothing has to be spaced
Edited by THE STIG, 26 July 2009 - 08:52 AM.
#17 THE STIG
THE STIG
  • 2,506 posts
Posted 31 July 2009 - 07:03 PM
tank fitted
fuel lines run to engine bay
belts etc fitted crank sensor mount made
moved throttle bodie back on inlet to give me a little more room and so filter fit under bonnet
wiring will be done tomorrow and ecu fitted
#18 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 31 July 2009 - 07:04 PM
#19 centralminimart
centralminimart
  • 17 posts
Posted 01 August 2009 - 05:46 PM
its looking good good good you really are something else all tho you feel like s..t you keep going hopefully get it firing up tomorow if ya want one come and have a look at imm central mini stand then see the stig
Edited by centralminimart, 01 August 2009 - 06:03 PM.
#20 THE STIG
THE STIG
  • 2,506 posts
Posted 02 August 2009 - 07:38 PM
have spark have fuel
now if i could only get my lap top to see the usb to serial port adapter could programme ecu
#21 THE STIG
THE STIG
  • 2,506 posts
Posted 15 August 2009 - 03:53 PM
well its running will upload a vid later :D
thanks to THE MATT and mighty for their help with the ecu
#22 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 15 August 2009 - 04:09 PM
Glad you got it sorted mate! :D
#23 THE STIG
THE STIG
  • 2,506 posts
Posted 15 August 2009 - 07:52 PM
as promised sorry about sound etc phones about dead
#24 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 16 August 2009 - 07:11 AM
Awesome, you taken it for a spin yet? Found somewhere to RR it?
#25 Jake Blues
Jake Blues
    TMF Moderator
  • 2,955 posts
  • Local Club: Central Minis
Posted 17 August 2009 - 08:47 AM
Nice work mate...looking forward to seeing it on Sunday!
#26 THE STIG
THE STIG
  • 2,506 posts
Posted 18 August 2009 - 08:36 PM
yep drove it around today :dontgetit: :w00t: :w00t: :w00t:
few things know know inlet temp is around 95c as dont have the colder fuel air charge had before
and accurding to my boost gauge is running 10psi on the standard pully and the standard bottom pully thats surplied in the kit
#27 Prawn
Prawn
  • 938 posts
Posted 19 August 2009 - 06:57 AM
not knocking the setup stig, but isn't 95 degree's incredibly high for a charge temp? My dailly runs around 20psi boost, and although it's got an intercooler, charge temps never exceed 35 degrees....
are these high inlet temps not the main reason the vmax (and other similar) kits need to run such low CR's when compared to turbo setups on similar boost? surely with lower inlet temps you could run a higher CR and still not suffer from DET.
#28 THE STIG
THE STIG
  • 2,506 posts
Posted 19 August 2009 - 07:12 AM
yep is high and may not be dead acurate going on what ecu is saying and yes proberly why they run such low compression ratios , dont know what the temp was on carb but was proberly a bit colder due to the lower inlet temp
thats why on mine am doing it blow through with a intercooler
Edited by THE STIG, 19 August 2009 - 07:14 AM.
#29 Prawn
Prawn
  • 938 posts
Posted 20 August 2009 - 06:53 AM
I'd like to see yours one day Stig, as I'm planning on doing exactly the same thing myself starting after Castle combe this year. I've got my charger, I just need to source some MPI pulleys, which is proving hard at the moment!
I was shocked at suggested CR's when I looked into suck through supercharging, over on turbominis people are running up to 10psi with 9:1CR and not suffering from DET, although that's on well intercooled setups running mappable ignition too.
Sorry for Hijacking the thread!
Impressive job converting it to injection yourself :)
#30 THE STIG
THE STIG
  • 2,506 posts
Posted 20 August 2009 - 04:35 PM
so would i lol
due to losing my job my supercharged engine is on hold indefanatly :kiss:
have all my pulleys etc and had my block bored got super charger inter cooler etc just have to what till get a job to finace the build
will chat about it at bh2n in less than 2 weeks :)
