How Much Grease For A Pot Joint
3 replies to this topic
#1 josh.evans
josh.evans
  • 1,439 posts
Posted 10 June 2009 - 10:17 AM
hi does it matter how much grease you put in the pot joint for when i get round to doing that
cheers
josh
#2 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 10 June 2009 - 03:26 PM
It is probably not too critical exactly how much grease you put in but far too little and the joint will fail, too much and it will pop the boot off and spray everywhere.
Why not go to a parts shop sometime when you are passing and ask for an inner boot kit, have a skeet in the box for the grease sachet and then you will know roughly whats needed, Then say "I am not sure its the right one" and they will put it back on the shelf.
Alternatively the unipart parts place over here has sachets of CV joint grease in stock which should be about right.
#3 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 10 June 2009 - 04:24 PM
If it's any help - the Sachets of grease that come in the CV boot kits from my local factors hold about 2 table spoons worth.
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 June 2009 - 09:02 PM
It will usually not be a full sachet, the sachets are universal and a Mini has small joints. A dry pot joint needs 50cc of grease, if there's some still in place then just use enough to top it up to around that level. The late CV joints use 30cc, I don't know whether the smaller early CV joints use less.
