Tink Version 4 / 5
276 replies to this topic
#121 alexcrosse
alexcrosse
  • 3,786 posts
Posted 18 January 2010 - 09:20 PM
I will definatly catch up with you in the show season!
lol yer i was there indeed! good times.
#122 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 18 January 2010 - 10:11 PM
we're toying with the idea of kidnapping him. :thumbsup:
#123 alexcrosse
alexcrosse
  • 3,786 posts
Posted 18 January 2010 - 10:37 PM
hmmm nah!
#124 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 18 January 2010 - 10:38 PM
Looks like I'm gonna have to get myself to MITP this year then!!
#125 alexcrosse
alexcrosse
  • 3,786 posts
Posted 18 January 2010 - 10:43 PM
aye indeed you will! im gonna have to try and get mine finished in time for it =p i decided a while ago im not going to any shows until mine is finished!
#126 HARBER07
HARBER07
  • 4,498 posts
Posted 18 January 2010 - 10:46 PM
I was sorta thinking that this year to be honest. I haven't really planned anything like IMM or L2B etc. Would rather get my engine built up if I'm honest.
#127 alexcrosse
alexcrosse
  • 3,786 posts
Posted 18 January 2010 - 10:51 PM
yer u got the right way of thinking chap! hopefully mine will be done soon :S got all my exams in may, so kinda screws it up. Mind you, the exciting ones are in july / august, MITP, DragWars and Castle Combe
#128 miniman retford
miniman retford
  • 3,553 posts
Posted 19 January 2010 - 10:15 AM
See you in 2012 then :thumbsup:
#129 alexcrosse
alexcrosse
  • 3,786 posts
Posted 19 January 2010 - 10:36 AM
thanks for that nige!
#130 alexcrosse
alexcrosse
  • 3,786 posts
Posted 19 January 2010 - 08:20 PM
bit more done today, had lunch with an old friend so didnt have too much time, and then had to take the pictures outside in the dark so yet again i apologize for the quality!
made up a little loom for the alternator ignition connection and light
all wired in nicely :P including the alternator light, alternator ignition and alternator live, then temperature sensors
and again :thumbsup: side of the block always looks rusty in pictures but isnt in real life, im going to have to paint it anyway and get some new bolts for the water pump i think.
got the wires fed through the main bulkhead grommet eventually! interior needs a good tidy up, need to start thinking about it now the cars almost done.
Should have the alternator running tomorrow, then im going to try and calibrate the lambda sensor, if it works "wooo", if it doesnt, i need a new sensor, i think ive broken this one running it cold and rich :)
Cheers,
Al
#131 alexcrosse
alexcrosse
  • 3,786 posts
Posted 20 January 2010 - 04:04 PM
right, it still runs! and after wiring the alternator (takes me ages to wire things because i coil and heat shrink everything) i fired it up and got over 14 volts :dozing: Sweeeet, so now all i have left to do is shim the engine and sort out the lambda sensor. Just charging the battery now to do some checks on the lambda sensor. Also cleared out the car, was full to the brim with rubbish from last years shows and the 16v build.
Anyway, heres the video, its a bit jumbled as it was long so cut bits out before putting it on the tube. Also ignore the oil pressure, the senders broken... again...
q78QgrsM9xc
Al
Edited by alexcrosse, 20 January 2010 - 04:04 PM.
#132 alexcrosse
alexcrosse
  • 3,786 posts
Posted 11 February 2010 - 11:30 AM
Well last weekend i fitted my new lambda controller and sensor which works fine! so cheers rd! I think it mayyy have been my fault the other controller broke, i hadnt insulated the end of an auxillary output wire 0-5v and I think it was shorting, so... my fault, damn!
Has a good weekend anyway, new setup wired in, TPS plug redone as it was faulty, shimmed the engine into it propper position and also dropped some stickers off at camp shonky.
Heres some random weekend pictures:
so getting more dont this weekend, alot of mapping, fixing the hot air blower output for the windscreen, might re route the water lines too. Then it just needs a clean and a good spank :)
Al
#133 alexcrosse
alexcrosse
  • 3,786 posts
Posted 13 February 2010 - 08:42 PM
well has a good day on the car. First of all got the new oil pressure gauge put in, nothing like a mechanical one, 60psi cold, which is good, should equate to around 40psi when warm, but only one way to find out!
Also rerouted the heater hoses and the hose to the expansion tank to neaten up the engine bay and inside, and prevent crimping.
this is how it began, lines going in above the cross member, not cool!
the lines re routed
and again
...and again
going to raise the ride height tomorrow, put a brake switch on the pedal box, and try and get it to run a bit better. After that the only jobs left - filter plate, mapping and VSS
Alex
#134 alexcrosse
alexcrosse
  • 3,786 posts
Posted 17 February 2010 - 04:55 PM
Ok, update from sunday.
Got some more pictures of the car in lights to show the new routing of the pipes
got the brake switch fitted and a VERY bad picture taken. Just got a roller switch and works a treat, fabbed up a little bracket to go on the pedal box.
sorry about the picture, rubbish camera.
got it running, idles fine, map cuts ignition at 1500-2000rpm so need to sort that out, spending this week build up a few base maps and go from there.
And raised it a little bit to stop the exhaust touching the ground, plus it was sitting on the bump stops. Want to do something about the front end, gap between the wheels and arches is quite big, but that can happen wayyy in the future.
Work for the weekend... vss, filter plate, mapping, drinking
Al
#135 minimad01
minimad01
  • 563 posts
Posted 17 February 2010 - 11:40 PM
wow just read threw your hole thread an i was amazed by how many conversions youv done ,looks good an sounds nice aswell looking at this thread has just made me relise that the stage 2 kit im now fitting on mine isnt nothing special when youv got people doing this ;D but o well in due time i think i will buy another mini an do the vtec conversion (providing money is there)lol
cant wait to get mine runniong again :P
