Did a few little jobs like plopping on the SBD coilpack and stuff.
pedal box didnt arrive, so i carried on with the wiring loom, found the reason it was so bad, was because of extra wires added after installation, making loops, so it was impossible to unravel.
So took all of it out, removed alot of wires, wrapped it in tackless matt tape, put the rest of the inline fuses into the fuse box. Then put the SBD wiring loom in, shortened the battery connection (was designed for a nova, bit of a stretch to the battery, ive just put mine to the starter motor). I had a hole low down where the shifter cable for the R1 engine used to be, so all looms have been routed through there. Final wiring install was the wideband lambda sensor (innovate LC1) which was simple enough.
Heres some pictures, bare in mind ALL of the wiring in the engine bay is in its finished position (appart from the water temp which isnt routed properly). so its damn tidy IMO
one for you matt, you were wondering about clearance etc
jobs for tomorrow : mount the rad, wrap the exhaust, looking at the pics, think i may need to paint the inside of my fg front
