Tink Version 4 / 5
276 replies to this topic
#151 alexcrosse
alexcrosse
  • 3,786 posts
Posted 01 March 2010 - 10:40 AM
Right, full weekend working on the little bits! Hopefully this little circuit will solve the problems ive been having with my tacho, optocoupler circuit.
Then set to work on the engine bay, first of all attacked the cambelt cover, had to modify it a little bit to clear the subframe but all in now. Also keyed and painted a new rocker cover, and took the horrific yellowness of the oil cap
BEFORE:
AFTER:
Getting these tested and new seals put in this week, better spray pattern... and closer to the base map i have!
Cheers!
Al
FAO Matt, Heres some pictures to give you an idea of my alternator clearance
#152 roofless
roofless
    Sticker Pimp
  • 7,215 posts
  • Local Club: central minis
Posted 01 March 2010 - 11:32 AM
Izzz Niccceee :cry:
#153 alexcrosse
alexcrosse
  • 3,786 posts
Posted 01 March 2010 - 12:04 PM
#154 alexcrosse
alexcrosse
  • 3,786 posts
Posted 13 March 2010 - 08:50 PM
Update time, got these injectors back after cleaning and testing. All balanced with each other perfectly. So spent today putting them in.
Then it refused to run properly, realized it was a bad plug, lots of cold starts running very very rich ruined it. So bought a new set and put them in... win! started poifectly.
The went for a spin! Had a bit of a worry, it was using alot of water once i got back from the drive, then realized it was just filling the rad properly once the thermostat opening. Filled it back up with water and went for another drive.
Pulls well, maps still a bit out but alright for running in. up to 4000 at half throttle it pulls like a train, nice to have some serious power back after the 8v period. And also nice to get back behind the wheel of a mini, nout else compares :thumbsup: lol.
9pjAGJrzyro
and yes, thats my happy face...
Cheers,
#155 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 13 March 2010 - 08:55 PM
So your happy face is the same as your ugly face??
(who'd have thunk it??)
#156 alexcrosse
alexcrosse
  • 3,786 posts
Posted 13 March 2010 - 09:16 PM
interestingly; its also the same as my climax face
#157 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 13 March 2010 - 09:20 PM
Don't know, I've never made you come???!!!
#158 alexcrosse
alexcrosse
  • 3,786 posts
Posted 13 March 2010 - 09:24 PM
you have, you just weren't there
#159 jayare
jayare
  • 2,093 posts
Posted 13 March 2010 - 10:28 PM
:thumbsup: :) :dontgetit:
#160 miRon
miRon
  • 1,993 posts
  • Local Club: SMAG
Posted 23 March 2010 - 07:23 PM
9pjAGJrzyro
Cheers,
NAAAAAA NAAAA NAAAAAAAAAAAAAAAAAA!!!!!
#161 captainjack15
captainjack15
  • 3,925 posts
Posted 23 March 2010 - 07:33 PM
Hell of a good mate!!
Love it :)
#162 george91
george91
  • 883 posts
Posted 24 March 2010 - 11:23 PM
Great project mate, this mini's had so many different engines this one is of my favorites though, should make a nice bit of power and still be a good daily, good luck with it, looking out for the next update.
Edited by george91, 24 March 2010 - 11:23 PM.
#163 alexcrosse
alexcrosse
  • 3,786 posts
Posted 25 March 2010 - 07:49 AM
LM.F.AO! good times... (why does tmf feel the need to censor abbreviations?!)
Love it :(
Cheers dude
>_<
Cheers mate, think itll be my favorite all round setup, if not ill have to dump my next engine idea in >_< LOL
Should be properly on the road soon, map seems alright, making det cans at the weekend so i can hear detonation better if it occurs (bit of tube attached to ear defenders), need a new battery because my lovely big one has failed. And also still a bit concerned about the lowness of the oil pressure, temped to shove a new pump on it, but it might just be the accuracy of a TIMs gauge (very likely)
Edited by alexcrosse, 25 March 2010 - 07:50 AM.
#164 josh.evans
josh.evans
  • 1,439 posts
Posted 25 March 2010 - 10:18 PM
hi well done done a nice job. Does it drive better than the r1 engine?Which one out the 2 you prefer. big question :(
Josh
#165 alexcrosse
alexcrosse
  • 3,786 posts
Posted 26 March 2010 - 11:46 AM
only times ive driven this 16ver so far all ive been thinking about is AFR and det! seems to drive well though. Cant compare the two yet until the 16vers run in, should be similar power but a bit more torque from this one compared to the R1. Dont no, 4 x 45mm throttle bodies sound great, but so does a 998 R1 engine at 12000rpm
