Airhorn Draining Battery!
21 replies to this topic
#16 captain kirk
captain kirk
  • 857 posts
Posted 07 June 2009 - 07:08 PM
relay no 87 to compressor
30 to fused permanent live
85 earth
86 horn switch
#17 lrostoke
lrostoke
  • 6,923 posts
Posted 07 June 2009 - 07:14 PM
This first one is how mine is wired, mine are twin horns not musical but wiring will be the same.
The purple wire is the old wire that connected to the spade connector on the old horn.
This 2nd one is how you would wire it using a seperate switch keeping your exisiting toot toot horn in place.
On both scenerios for the positive on the battery you would use the battery lead connection on the solenoid.
On the fuse box the connection you want is either the White wire, this is ignition fed live before it goes through the fuse box. or the green wire this is ignition fed live after going through the fuse.
lastly the pictures I found through google and modified to show a horn compressor not spotlights, but rest is same :P
Edited by lrostoke, 07 June 2009 - 07:18 PM.
#18 Phaeton
Phaeton
  • 1,055 posts
Posted 07 June 2009 - 07:39 PM
You have to use the 2nd diagram as it would be illegal to have the musical horns as your audible warning device i.e. Horn LOL
Alan...
#19 lrostoke
lrostoke
  • 6,923 posts
Posted 07 June 2009 - 07:41 PM
I thought that myself but thought I'd give both diagrams :P
#20 captain kirk
captain kirk
  • 857 posts
Posted 07 June 2009 - 07:47 PM
The second diagram is how i have mine wired up
#21 minidan
minidan
  • 2,354 posts
  • Local Club: LSMOC
Posted 07 June 2009 - 08:32 PM
Alan...
i will try the 2nd diagram as it is very different to the way my instructions show.
and i haven't wired the musical horn up to my existing horn as i have used a small seperate push button.
#22 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 08 June 2009 - 01:13 PM
A bad earth will not be the problem. A bad earth connection will appear as an "open" and will interrupt current flow, not make more current flow.
A bad earth can cause your battery to go flat though as ive had this problem on a few cars especially on minis.
Just to be clear, I was not suggesting bad earths don't cause problems. My point is/was that adding a new horn system isn't going to create a bad earth. A bad earth at the battery will make it difficult to recharge the battery... but it won't drain it.
