New Product 3 of 12:
Rear Pocket/Bin Liners (Pair)
Manufactured in your choice of premium automotive carpet or luxury vinyl, with a line of decorative stitching along the top edge.
(Click on the image above to be directed to the website.)
Available for all MK's and variants of the Mini that have a rear passenger section:
MK1/MK2/MK3 (Onwards) Saloons & Clubman's (1959 to 2000). Mk1/MK2 Countryman (1960 to 1969). Clubman Estate (1969 to 1980).
from £14.99 (2 piece kit)
Classic Mini Interiors
#76
Posted 02 March 2010 - 07:45 PM
#77
Posted 02 March 2010 - 10:45 PM
New Product
Front Door Check Straps (Pair)
Manufactured from luxury vinyl, with a line of decorative stitching along the edges, internally reinforced with a strong nylon ripstop material and padded with a 6mm upholstery foam.
Available for all Mini's fitted with external door hinges:
MK1/MK2 Saloons (1959 to 1970). Mini Van’s (1960 to 1982). Mini Pick-up’s (1961 to 1982).
from £7.99 (2 piece set)
so how do these fit?
#78
Posted 03 March 2010 - 10:19 AM
In exactly the same way as the originals
They attach to the door pillar post (or inner A panel if you like) using the standard metal bracket and then attach to the door using the standard (already cut) screw holes - Please Note you will need to punch 4 holes in the straps to insert the bolts through your plates.
#79
Posted 04 March 2010 - 05:00 PM
New Product 4 of 12
Rear Wheel Arch Covers (Pair)
Manufactured in your choice of premium automotive carpet or luxury vinyl and backed with a 6mm upholstery foam, also with a line of decorative stitching along the top edge.
from £9.99 (2 piece kit)
#80
Posted 06 March 2010 - 04:54 PM
New Product 5 of 12
Rear Pocket/Bin Bottoms (Pair)
Manufactured from fibreboard and covered in your choice of premium automotive carpet or luxury vinyl, with a line of decorative stitching along the edges.
MK1/MK2 Saloons (1959 to 1970)- Right hand side photograph
MK3 (Onwards) Saloons & Clubman's (1969 to 2000) - Left hand side photograph
Mk1/MK2 Countryman (1960 to 1969) and Clubman Estates (1969 to 1980) - Middle photograph
#81
Posted 08 March 2010 - 03:22 PM
New Product 6 of 12
Front Door Fillets & Liners
from £19.99 (4 piece fillet set) or from £14.99 (2 piece pocket liner set).
#82
Posted 10 March 2010 - 05:36 PM
New Product 7 of 12
Lower Dash Tray Liners
Available for all MK3 (onwards) variants of the Classic Mini:
from £19.99 (1 piece kit)
Edited by roberts, 11 March 2010 - 04:38 PM.
#83
Posted 12 March 2010 - 04:33 PM
New Product 8 of 12
Lower Dash Tray Padded Covers
Manufactured in your choice of premium automotive carpet or luxury vinyl, with a line of decorative stitching along the edges and backed with a 6mm upholstery foam.
Please Note Lower Dash Tray Covers made need to be cut/shaped to fit around objects such as heater pipes.
Available for all MK's and variants of the Classic Mini:
from £14.99 (1 piece kit)
#84
Posted 14 March 2010 - 02:35 PM
New Product 9 of 12
Centre Binnacle Dash Liners
Available for all MK's and variants of the Classic Mini fitted with centre speedo binnacles, that have oil pressure & water temperature gauges either side (Oval Binnacles).
Also available for all MK's and variants of the Classic Mini fitted with centre speedo binnacles, that DO NOT have oil pressure & water temperature gauges either side (Circular Binnacles).
from £24.99 (2 piece kit)
#85
Posted 16 March 2010 - 04:34 PM
New Product 10 of 12
Offset Binnacle Dash Liners
Available for all MK's and variants of the Classic Mini fitted with ‘line of sight’ 2 or 3 clock binnacles:
Clubman Estate (1969 to 1980). Mini Van’s (1960 to 1982)
#86
Posted 18 March 2010 - 04:25 PM
New Product 11 of 12
Estate Load Bay Flooring Kit
Manufactured in your choice of premium automotive carpet or luxury vinyl and backed with a 6mm upholstery foam. The kit comes complete with the required floor clips - including the clips, spiked clips and studs. Which means that you don’t have to 'faff' around removing the clips from your old trim, to install them to your new bits.
Please Note Floor clips are not attached to the kit - 8 clips are supplied.
Available for:
from £39.99 (2 piece kit)
#87
Posted 20 March 2010 - 08:50 PM
New Product 12 of 12
Estate Window/Back Seat Trimmings Kit
Two options available:
1) The first option is manufactured from fibreboard and covered in your choice of premium automotive carpet or luxury vinyl, with a line of decorative stitching along the edges.
2) The second option is manufactured from hardboard (for extra durability) and covered in your choice of premium automotive carpet or luxury vinyl. However, hardboard kits are not available with the line of decorative stitching along the edges.
Please Note The 2 pieces of back seat trim that we supply do not come with the metal plate that is found on the standard pieces of trim. As a result, you will have to remove the metal plate from your original trim and fix it to your new trim.
Available for:
from £69.99 (13 piece kit)
#88
Posted 22 March 2010 - 01:32 PM
I haven't been on your website in quite a while but am going off to have a look now and may well be buying lots of stuff this year / putting them on my birthday and christmas lists!
#89
Posted 22 March 2010 - 04:07 PM
What bits do you have in mind?
#90
Posted 30 March 2010 - 02:54 PM
Another New Product
The first of 2 Speaker Pod related ones...
Speaker Spacers
A product developed due to popular demand and designed to enable the installation of 6.5" or 6"x9" speakers on the Mini parcel shelf, within the standard 13.5cm factory cut holes. The spaces work by raising your speakers off the parcel shelf, which allows the speaker cone to sit within the standard factory cut holes - simply select the desired depth whilst choosing your trim (1.8cm or 3.6cm).
Only standard MK5 (onwards) Mini's have factory cut 13.5cm holes on the parcel shelf, older Mini’s (Mk1 to Mk4 – prior Mk5/1990) do not have these 13.5cm factory cut speaker holes on the rear shelf.
Click the image above to be re-directed to the Optimise Automotive website.
Please Note We cannot guarantee that our Speaker Spaces range will raise all makes and models of 6.5" and 6"x9" speakers enough to fit within the standard holes. As a result, please check to make sure that your speaker cones fit into the holes on your parcel shelf, within a maximum mounting depth of at 3.6cm (see the diagram below for help).
The maximum mounting depth of 3.6cm is measured from the to surface of the parcel shelf to the underneath of the mounting gasket (the thing you screw through to attach the speaker).
The spacers are secured to the desired location using the M4 bolts & lock nuts provided. Please see "Installation Information" below for details.
from £9.99 (Pair)
