Cigerette Lighter
#121
Posted 03 June 2009 - 12:03 AM
if you need any help with fitting yours or whatever just PM me or just post up in here as ill most likely be on all day
hopefully my little guide will help, i managed to do what ive done so far without looking at minifinity guide all the way through so it isn't hard to do.
time consuming bit is stripping wire, crimping and heat shrinking but shouldn't talk long
#122
Posted 03 June 2009 - 12:09 AM
#123
Posted 03 June 2009 - 12:11 AM
if your struggling to get down to halfrauds why don't you just order all the stuff offline?
#124
Posted 03 June 2009 - 12:26 AM
you know that you've wired the positive cable up. have you just left it as it is with the connecter exposed or have you covered the other terminal up.
#125
Posted 03 June 2009 - 12:28 AM
how do you mean?
#126
Posted 03 June 2009 - 12:34 AM
#127
Posted 03 June 2009 - 12:36 AM
theres no ring terminal on it yet as i havent decided on position of cigi lighter but once that is sorted i will cut the wire to the right length, crimp a terminal to it and heat shrink it but atm its just left how it was when i got it
#128
Posted 03 June 2009 - 12:49 AM
#129
Posted 03 June 2009 - 12:52 AM
i dont know tbf, on the back of the cigi lighter i have it says to make sure u was a 15-20amp fuse so therefore would need wiring at higher amps to suit the fuse
does sound wierd but could be possible
#130
Posted 03 June 2009 - 12:59 AM
#131
Posted 03 June 2009 - 01:02 AM
sounds like your saying there is a shop called 'WHAT' haha
#132
Posted 03 June 2009 - 06:09 PM
managed to get mounting bracket done today as me and my dad went to see a friend who has lots of tools.
all needs to be done now is sanded down, holes drilled for mounting and then spraying.
only problem being i cant get the cigi lighter out of the hole now
#133
Posted 03 June 2009 - 06:16 PM
Cheers Jordan
#134
Posted 03 June 2009 - 06:18 PM
do you mean the actual plugs that are say connected to chargers and the like?
Edited by shorty, 03 June 2009 - 06:19 PM.
#135
Posted 03 June 2009 - 06:21 PM
try looking around on ebay
I have tried hard to know what to search for.
I mean like a bit of plastic thats flat and fits over the hole to cover it up if you know what i mean.
