Cigerette Lighter
150 replies to this topic
#91 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 02 June 2009 - 01:21 AM
Earthpoints not a really big problem make sure the contact is secure and clean! thats the biggest issue!
Im orff to bed, good night you 2!
#92 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 02 June 2009 - 01:23 AM
gotcha good clean points are a must
good night >_<
#93 redhotminilewis
redhotminilewis
  • 565 posts
Posted 02 June 2009 - 01:24 AM
okay sounds good.
cya liirge. good night.
so how much do u reckon this is gunna cost altogether?
#94 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 02 June 2009 - 01:27 AM
well i spent 17 quid on the wire, fuses, fuse holder, ring terminals, spade connectors
still gota buy the heat shrink
buying the ring terminals will either come as a pair or in a box of a fair few
and depending on what fuse holder you are able to buy you may need spade connectors to be able to put the fuse holder in between the wires
#95 redhotminilewis
redhotminilewis
  • 565 posts
Posted 02 June 2009 - 01:30 AM
yh, sounds like the best part of £20 lol.
not bad at all for a cigerette lighter. well i dunno if i will be able to get the parts 2moro because i cnt get a lift so if you do do this 2moro PM me bout how you get on and take sum pictures of the solenoid connection or summit lol. create a better guide then the minifinity one lol.
#96 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 02 June 2009 - 01:33 AM
better part of 20quid but an intersting convo with the motorworld bloke on cars lol
yeh i think i will make some sort of progress diary type thingy
you not able to get the bus down or anything then?
#97 redhotminilewis
redhotminilewis
  • 565 posts
Posted 02 June 2009 - 01:37 AM
actually i think i probably could. ill have to take a strol down to my local bus stop and see if it can take me there. really wana do this now lol. i probably wont ever use it but its guna be a learning curve. something i need to do because i really wana get into proper mini restorations and i just lack knowledge and experience.
or i cud beg my GF's mum to give me a lift up there. that would be sweet lol.
#98 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 02 June 2009 - 01:39 AM
haha begging is always the way lol
im very tempted to fit mine now although mine will be used for charging satnav/phone and runnin my cb radio
so its worthwhile for me to have one in my car.
it will come in handy at some point
#99 redhotminilewis
redhotminilewis
  • 565 posts
Posted 02 June 2009 - 01:41 AM
yh. always good to have the facility there. did you say that you are going to run a CD radio of it? how will you do that?
#100 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 02 June 2009 - 01:44 AM
lol no not CD radio i said CB radio haha
#101 redhotminilewis
redhotminilewis
  • 565 posts
Posted 02 June 2009 - 01:47 AM
oooo ryt lol. wats a cb radio? lol.
ive just had a thought. if i connect up the 27 amp wire and put a spade splitter could i run one lead of to run the cigerette lighter and the other one to power my CD radio with?
#102 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 02 June 2009 - 01:49 AM
there like walkie talkies only can operate over a longer distance, lorry drivers have them.
urmm i can't help you there, is your radio not wired up then?
#103 MiniMonty
MiniMonty
  • 1,802 posts
Posted 02 June 2009 - 01:14 PM
Check this link for a step by step on fitting a lighter....
http://www.minifinit...e...207&t=77888
Best wishes
Monty
#104 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 02 June 2009 - 01:35 PM
bit late for that monty its already been posted twice at the start of this thread >_<
#105 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 02 June 2009 - 04:36 PM
my little guide of todays work on fitted cigi lighter in
Attached File  DSC00109.JPG   106.58K   13 downloads
remove splash guard
Attached File  DSC00110.JPG   71.85K   10 downloads
attempt to locate starter motor with main feed from battery
Attached File  DSC00111.JPG   51.83K   9 downloads
discovered this on my carb lol no relevance to cigi lighter
Attached File  DSC00112.JPG   70.06K   9 downloads
location of starter motor behind the grill...oh joy :turtle:
Attached File  DSC00113.JPG   66.09K   9 downloads
grill removed..easier than i though lol
Attached File  DSC00114.JPG   56.64K   13 downloads
main feed located..i hope (if anyone who knows sees this tell me this is the right one to connect it to please lol
Attached File  DSC00115.JPG   254.84K   7 downloads
my poor crimping skills but 8mm ring terminals fit perfectly on to the bolt that the main feed is connected to
Attached File  DSC00117.JPG   488.89K   8 downloads
heat shrink tubing applied - also applied to every other terminal connection :)
Attached File  DSC00120.JPG   360.89K   11 downloads
live wire now connected up an nut tightened fully
Attached File  DSC00121.JPG   385.57K   8 downloads
location of internal release for bonnet ideal for cigi live wire as it was closest one.
Attached File  DSC00122.JPG   350.51K   7 downloads
wire through hole and into the car finally
Attached File  DSC00123.JPG   292.05K   14 downloads
blue thing is location for earth wire
would of finished it and actually have it fitted only i didn't have a mounting bracket for the lighter so i left it at that
Edited by shorty, 02 June 2009 - 04:38 PM.
