Cigerette Lighter
150 replies to this topic
#46 redhotminilewis
redhotminilewis
  • 565 posts
Posted 02 June 2009 - 12:31 AM
yh, i need heatshrink to. or can you use electic tape instead?
also i found this as a in line fuse holderlink here would this be ok? its not 27 but its all halfords do under 27 amp
Edited by redhotminilewis, 02 June 2009 - 12:32 AM.
#47 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 02 June 2009 - 12:32 AM
Oh mate, the answer to every mini problem is...
"Mate....Get me the bigger Hammer for over there"...
#48 liirge
liirge
  • 4,097 posts
Posted 02 June 2009 - 12:33 AM
Heatshrink is a Professional and good job....
Loom tape or Electrical tape will do though, i have a fear about car electrics, too many times ive heard about classics going up in flames thanks to bad wiring!
#49 redhotminilewis
redhotminilewis
  • 565 posts
Posted 02 June 2009 - 12:34 AM
yh, or ''you got a chip in your windscreen, get the hammer a minute. that should straiten it out a bit''
#50 shorty
shorty
    Short Guy
  • 3,606 posts
urmm blade fuses should be ok to use
personally im going for glass ones seen as my whole car runs of inline fuses with the glass type ones..it confuses the best of people lol
halfrauds shud do the glass ones as well plus they are smaller so wont get in the way as much as the blade ones might
as for electric take i presume you could but again id rather use heat shrink as i always mess up when using tape lol
#51 redhotminilewis
redhotminilewis
  • 565 posts
Posted 02 June 2009 - 12:36 AM
now im scared lol. *buys a fire extinguisher* >_<
#52 liirge
liirge
  • 4,097 posts
Halfords do the glass ones, to confirm.
Yer heatshrink is the best, whats your favorite method for heating it?
#53 liirge
liirge
  • 4,097 posts
Posted 02 June 2009 - 12:37 AM
Yer Fire extinguisher standard mini equipment...no jokes mate
#54 redhotminilewis
redhotminilewis
  • 565 posts
Posted 02 June 2009 - 12:38 AM
yh, heatshrink is pretty cheap. ill go see if i can get sum off that stuff aswell then lol.
like these fuses? fuses!
#55 redhotminilewis
redhotminilewis
  • 565 posts
Posted 02 June 2009 - 12:39 AM
dunno, never done it before lol. i should really do more >_<
#56 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 02 June 2009 - 12:41 AM
yep those are the fuses just get a fuse holder that works with those they dont cost much.
so far my electrics have been fine seen as i havent got a mini fuse box to be concerned with haha
fire extinguisher is in the back though just to be safe lol
never actually used heat shrink before so ill either use a ligher or a small kitchen gas blow torch hahaa (on low settin ofcors)
#57 redhotminilewis
redhotminilewis
  • 565 posts
Posted 02 June 2009 - 12:43 AM
right awsome.
shopping list:
glass fuses
fuse holder
27 amp wire
ring connectors
heat shrink tubing
packet of hula hoops
have i missed anything? lol
Edited by redhotminilewis, 02 June 2009 - 12:43 AM.
#58 liirge
liirge
  • 4,097 posts
Posted 02 June 2009 - 12:44 AM
yer yer, lighter doesnt always work properly, best thing to use i found was one of those "Turbo" lighters, i.e.the little ones that are basically blow torches so you can use them in the wind to light your cig. apparently a hairdryer works...i personally think they'll be to cold.
Yer Fire extinguisher always a good move for the emergency equiment.
#59 liirge
liirge
  • 4,097 posts
Posted 02 June 2009 - 12:45 AM
right awsome.
shopping list:
glass fuses
fuse holder
27 amp wire
ring connectors
heat shrink tubing
Crate of Kronenbourg?
#60 shorty
shorty
    Short Guy
  • 3,606 posts
Posted 02 June 2009 - 12:46 AM
right awsome.
shopping list:
glass fuses
fuse holder - for glass fuses >_<
27 amp wire - in black and in red
ring connectors - of a decent size to be able to go round points on solenoid and whatever you use for earthing it
heat shrink tubing - make sure it will fit over the 27amp wire
packet of hula hoops - bottle of coke lol
sounds like you got most of the stuff it will be a case of you get home and remember you forgot something though lol
