Cigerette Lighter
#16
Posted 01 June 2009 - 11:42 PM
halfrauds have the inline fuses i believe and all you will need is standard glass fuses cylinder type
as for the wire if you know where to get 42amp wire from let me know
if not next one down seems to be 27amp
ring terminals and stuff im sure halfrauds might do them but id also try B+Q or local electrical stores
#17
Posted 01 June 2009 - 11:44 PM
#18
Posted 01 June 2009 - 11:46 PM
#19
Posted 01 June 2009 - 11:47 PM
what colour ignition wire do i need to connect it too?
#20
Posted 01 June 2009 - 11:48 PM
#21
Posted 01 June 2009 - 11:49 PM
Just been thinking you cant put a heavy duty cable with a big fuse and run high amps off it, you've taken it off a tiny wire, because you'll melt that little wire, so your in the same position. need to find a decent source for the wire.
o yeah, grrrrr so im gunna have to do what is done on minifinity by connectin it to the starter....... ummmm it maybe the tiredness but wheres the starter?
#22
Posted 01 June 2009 - 11:50 PM
going from the guide its behind the grill though
#23
#24
Posted 01 June 2009 - 11:52 PM
sorry to hijack by the way but will running a 27amp wire still be ok despite that guide says 42 amp wire?
#25
Posted 01 June 2009 - 11:54 PM
As long as you have a fuse below the 27Amp it will be fine, and if the fuse keeps belowing you know you need to up the Wire spec and fuse to match.
#26
Posted 01 June 2009 - 11:55 PM
Well i think it means the Solenoid. attach it to the battery end of that, i mean the Starters not in use all the time, so im pretty sure the guide means the Solenoid.
right well now i have to find a way of conecting it to the solenoid. how would you go about it.
dw, i was just gunna ask the same thing lol
#27
Posted 01 June 2009 - 11:58 PM
as for connecting it to solenoid i would also like to know this
#28
Posted 02 June 2009 - 12:00 AM
#29
Posted 02 June 2009 - 12:01 AM
#30
Posted 02 June 2009 - 12:02 AM
might get mine connected up 2mz although i need a mounting bracket for the cigi lighter now 'doh'
