Cigerette Lighter
#136
Posted 03 June 2009 - 06:23 PM
im not sure if you can buy them individually but i could be wrong.
could try going to a scrapyard and see if theres any down there
or try halfords
#137
Posted 03 June 2009 - 06:24 PM
ohhh i know what you mean...urmmmm
or try halfords
Lol good. Haven't seen them in halfrauds not looked too hard though.
Might have to try a scrapyard then. Cheers.
If anyone else finds any a link would be awesome
#140
Posted 03 June 2009 - 08:31 PM
i wouldnt order from there either tbf
#141
Posted 03 June 2009 - 11:49 PM
theres a few on this page The Page
by the way thats coming along really nicely now. have you got it working yet or did you just make the bracket?
#142
Posted 03 June 2009 - 11:53 PM
i tested the light on it and that works though aha
#143
Posted 03 June 2009 - 11:55 PM
#144
Posted 03 June 2009 - 11:58 PM
you can still do some of the stuff indoors if it does rain
just strip and crimp some of the wire that can be done
#145
Posted 04 June 2009 - 12:01 AM
#146
Posted 04 June 2009 - 12:04 AM
im just lazy so takes longer than usual
plus wen i was crimping and heat shrinking either the crimp didnt hold well or the heat shrink bubbled so i had to strt over again
i also managed to cut the wire for the fuse to short so i had to do something with that to be able to make it useful again lol
#147
Posted 04 June 2009 - 12:18 AM
how does your in line fuse holder keep the wires in place? like the connection? is it a spade terminal or is it held by a screw or something? and how far did you put the inline fuse in after you connected it to the solenoid? did you connect ot really close to the solenoid or in the middle?
#148
Posted 04 June 2009 - 12:29 AM
the fuse i had was an inline one with wires coming of it with spade terminals attached to each end it is pretty rubbish tbf but ill see how long it holds up
i did mine by guess work and it was just luck tbf but id say have it half way in or something, mine is basically right next to the windscreen fluid bottle and ive used small cable ties to keep the wire running along the headlight loom
#149
Posted 25 October 2010 - 04:27 PM
Just wondered if anyone knew of a fitting guide for the cigarette lighter? the link http://www.minifinit...e...207&t=77888 no longer works!
Any help much appreciated!
Tim
#150
Posted 25 October 2010 - 07:33 PM
