Is there a correct type to use in my 1275? Are they made for different blocks with differing design or what?
Any help would be great, I don't want to make a mistake with these.
Edited by Deathrow, 30 May 2009 - 12:12 PM.
Posted 30 May 2009 - 12:10 PM
Posted 30 May 2009 - 01:30 PM
Posted 30 May 2009 - 02:14 PM
Thanks mate!From the big yellow bible I remembr that ones with holes can crack at very high rpms.
2secs, I shall check the shelf.
Quote;
"If you can use the type of cam follower without the hole in it then so much the better, as the oil hole dosen@t really appear to be conducive to the extra life. Plenty of oil finds it way around the cam follower without the hole."
Vizard - How to tune the A-Series engine. P334 Third Edition.
Posted 02 June 2009 - 01:05 AM
Posted 02 June 2009 - 01:12 AM
Posted 02 June 2009 - 04:31 AM
the hole also weakens the follower, probably not applicable to your usage...but still a reason to use a solid job!
Posted 02 June 2009 - 08:03 AM
