Just A Clicking Sound When Ignition Is Turned
16 replies to this topic
#16 finch661
finch661
  • 2,339 posts
Posted 27 May 2009 - 10:03 PM
a big screwdriver usually works. you could get a bit of old radiator hose and put a large spanner in one end and use the pipe as a handle?
#17 Zacherius
Zacherius
  • 525 posts
  • Local Club: M4MINIS
Posted 27 May 2009 - 10:41 PM
Mine was doing this just two days ago and found it was the starter sticking. I did the insulated pliers on the solenoid thing but doesn't tell you whether its the starter or solenoid really. I used a meter onto the lead at the starter and it showed the voltage at the starter so I knew the solenoid was ok.
I removed the starter, reattached with one bolt ( so on the outside and did again, just to confirm the starter wouldn't spin ( as got told it could be the engine stuck ?!?!
However, it was the starter, I undid the small nuts and immediately found two of the four prongs/bushes inside were stinking and not sat right. I cleaned it up and hey presto. We have life.
