Minivan Side Panel
#31
Posted 16 October 2011 - 12:34 PM
#32
Posted 16 October 2011 - 12:40 PM
At least it would look better than a flat panel or the windows replaced with a flat panel.
Jordie
#33
Posted 16 October 2011 - 09:51 PM
#34
Posted 17 October 2011 - 11:51 PM
Edited by DAVEY_C, 17 October 2011 - 11:51 PM.
#35
Posted 19 October 2011 - 04:11 PM
#36
Posted 24 October 2011 - 01:42 PM
#37
Posted 14 November 2011 - 03:39 PM
#38
Posted 06 December 2011 - 09:32 PM
Post here if your interested. Price to be confirmed dependent upon production time and costs.
Jordie
#39
Posted 07 December 2011 - 12:16 AM
are they both full sides you propose or just window panels??
cheers
#40
Posted 07 December 2011 - 07:55 PM
Currently we would be selling these panels as is, so you can decide if you bond them on, add brackets etc. Later we will also make kits with a "fitting kit" to convert an estate to a van using these fibreglass panels.
We have done the first mould today, it looks fantastic. We are hoping to lay up the mould to create a panel tomorrow or friday. I can tell you the fibreglass panel/mould is alot stronger than the metal panels we have, the panel doesnt flex like the metal one so you wont need the support as found on the original vans.
We would post to ireland at cost yeah
I am a registered trader on TMF, incase anyone out there doesnt know that.
Jordie
#41
Posted 09 December 2011 - 04:59 PM
First pull from the mould. Near side panel shown. Few minor defects in the gel coat, which would be fixed when preped and painted anyhow. But will improve the mould to stop this on the next pull. Note this picture shows it as it is pulled from the mould, no trimming or tidying as took place, or prep work.
Thats the full panel from swage line to the roof, the B post join (slanted edge at top of B post) and to rear edge of the panel. So you could trim down and blend in or use the full panel and blend in depending on what your fitting it too etc.
Anyone interested show interest now, as we will be producing these shortly to sell. Price estimated at £150 a pair including next working day UK courier service*.
* next working day from dispatch. products not in stock or produced to order will be sent next day delivery after completion.
Jordie
#42
Posted 11 December 2011 - 02:26 PM
#43
Posted 12 December 2011 - 10:32 PM
My friend is busy making brackets so we can fibreglass stainless steel brackets into this and rivet into the window channel...... Bit of bonding adhesive around the edges then prep/filler the edges....perfect.
Hopefully you can see what it will look like with some prep and paint
#44
Posted 19 December 2011 - 07:52 PM
#45
Posted 20 December 2011 - 11:00 PM
