Daughter Zoe's Mini - Yeah Right!
723 replies to this topic
#91 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 19 October 2009 - 07:39 PM
Thought it was about time I gave a small update.
If you remember at the end of the last episode I said the rear radius arms were next.... Well, here goes.
Not the most interesting of updates but my experiences may help someone.
Firstly, unless you happen to be an engineering whizz, or have a pal with all the kit at work (that's me), or just simply want to be able to say "I did that" (that's me as well), I would suggest that it is much easier and possibly cheaper (if you have to buy the tools), to buy exchange arms.
The befores!
I thought I might be able to get away with this one, bit of wet & dry you know!!!!!!
The picture doesn't really show just how bad it was. The other side looked almost new but I wasn't going to do just one.
Getting the old bearings out was a bit of a pain. The needle bearing on the inner came out okay but the bronze bush had to be cut with a hacksaw blade and then pulled out in pieces.
After trying very unsuccessfully to pull the bush in using a threaded rod I enlisted the help of my pal and took them off to his place of work.
We turned down the old (best) shaft so that the new bush fitted over.
Then after putting in the plastic grease guard and fitting the needle bearing, we packed it up with big thick washers and pulled the bush into place. Using the old shaft with the bearing in place meant the bush pulled in nice and straight. (no pics of this bit sorry)
Once fitted we needed to ream the bush to size.
Re worked the old shaft once again to give a point.
Then with a borrowed 13/16 reamer we assembled the arm on the lathe before spinning up and using the tool carriage to gently push the arm accross the reamer.
Once cleaned out and after a slight bit of fettling the new pins fitted a treat.
All in all a fairly straightforward mornings work but as I said at the beginning, without the correct equipment it would have been a near impossible job to do well.
Next up, we're back on wheels, that's right wheels!!!!
Thanks for looking
Steve
#92 Mini Basher
Mini Basher
  • 424 posts
  • Local Club: Mini Foresters
Posted 19 October 2009 - 10:40 PM
Hi Steve
Nice piece on the radius arms, like you said unless you got the tools or know someone that has, the best option is to either get new or exchange arms, It'll be good to see your car back on it's wheels again, big step in the process of going forward
Andy
#93 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 25 October 2009 - 07:08 PM
Hi Steve
Andy
Thanks Andy.
It's one of those jobs that now I know how, and have the modified bars etc it would be a piece of cake to do again. It's just that it isn't one of thoes jobs that need doing regularly.
Cheers Steve
#94 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 27 October 2009 - 07:42 PM
Just a very quick update with some pictures to show I wasn't lying and we really are back on wheels!!!!
Only for a short while as I now need to be able to move the car in and out of the garage to work on now the weather has gone off.
Subframe back on un painted. Once the body work is further on, I will have the frames powder coated or similar.
Wheels !!! What a milestone !!!
Definately think I'm gonna need those wide arches.
I have now put the old wheels back on as I don't want the shiny new ones getting damaged.
That's all for now, just wanted to share.
Have fun
Steve
#95 rosco454
rosco454
  • 908 posts
Posted 27 October 2009 - 07:57 PM
Great stuff thats a big one to tick off the list!
#96 ScottyBoi
ScottyBoi
  • 1,128 posts
Posted 27 October 2009 - 08:00 PM
Awesome progress Steve!
Well done! :)
#97 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 27 October 2009 - 08:10 PM
Fantastic to see this back on its wheels, even if it is for now!
Good work!
#98 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 27 October 2009 - 10:49 PM
Getting closer Steve!!
#99 dell_boy
dell_boy
    lovely jubbley
  • 57 posts
Posted 28 October 2009 - 12:00 AM
just read this through, your doing an awesome job well done :lol:
#100 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,851 posts
Posted 28 October 2009 - 01:51 PM
Love this project, the pictures are of good quality and there's always a decent write up.
Keep up the good work :lol:.
#101 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 28 October 2009 - 02:20 PM
brilliant!loving the lathe action pics :lol:
#102 benb12
benb12
  • 1,483 posts
Posted 28 October 2009 - 04:40 PM
Lovely wheels, lovely arches, lovely choice of colour... lovely. :lol:
#103 Mini Basher
Mini Basher
  • 424 posts
Posted 28 October 2009 - 05:57 PM
Hi Steve
Cars coming on a treat mate, reached a big milestone now you've got it back on four wheels. Keep up the good work
Andy
#104 minimaff
minimaff
  • 695 posts
  • Local Club: Barnsley mini club
Posted 28 October 2009 - 07:29 PM
Very nice project, keep up the hard work, is it your daughters or yours lol
#105 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 29 October 2009 - 07:35 AM
Many thanks for the kind comments.
It really makes a difference and enourages me to keep working so I can give another update.
As for the "is it your daughters or yours"? minimaff... Well, that depends on who you ask!!
Regards
Steve
