Hi All, and time for another update
Had to get the megajolt ring back in place , and tidy up the sensor bracket a little. I was going to do a different one, but as they say, "if it aint broke"
Clutch & breather in place. I do like DSN quality
Head on
Rockers - These will prove to be a pain
Now I have the new roller door on the garage, I can use a ceiling mounted lift rather than a hoist. We toyed with the idea of a box section beam and some others. In the end, we drilled right through the ceiling, the wooden joist, and put a threaded bar with a lift hook. The top is in my office above the garage so not really an issue.
Out with the old
Spot the difference
I thought I would have to do a lot of work in the engine bay, but a clean up using de-greaser and a hose and I was pleasantly surprised.
A bit of playing around with the exhaust to remove the manifold from the pipe. The engine came out with it on, but no way it was going back in.
Ready to lift - Note the naff rocker cover. That's a story for later.
And up we go
And we're in
Earth strap was one of the first jobs, in case I forgot
Drilled the thermostat as I have lost the bypass
Took the plugs out and spun over on the starter to gain oil pressure. No joy
Oil was coming out of the pressure pipe, but here was only going to be one thing for it, and that was to fire it up and see.
Fitted the old 1 1/2 carb as I knew that worked. Hit the start button and it fired instantly. The oil light went out and we had 75psi. Phew
Shut it down straight away as we hadn't done the coolant. Did you know the 1275 top hose is different to the 998? I do now !!!
Much playing around followed, complete with cursing frustration and the odd bruised knuckle as I tried to fit parts, all bought from reputable suppliers which frankly, didn't fit!
But I was relieved it ran so I'll leave it there and update a little later.
Many thanks for stopping by
Regards
Steve
