Good afternoon fellow TMF'ers
Time for a little update.
Ethel: Thanks for the heads up on the light, but in the end I decided to go with 2 of the small marker type lights which I used on the rear "C" pillars. Small & self adhesive for ease. (not put them in yet though)
I spoke in one of my previous posts about Megajolt. I want to have a degree of adjustability for the new engine, there's a couple of other options I can utilise from the outputs, and, as like with a lot of things mini, I fancied a play.
My theory is to get it up and running on the existing 998, rather than install it with the 1275 (when it gets done) and have too many new things on the go at the same time. This way I can fit it, play around and know that when the engine swap comes along, it should be straightforward at start up.
So, with the help of the people that are TMF, I got some good ideas on where to put things, and with the quest to keep the wiring as tidy as possible, have also had a play around with some of my own ideas.
Got my unit from trigger wheels (just the basic unit with MAP sensor) as the difference on price from the US wasn't worth the gamble if I got caught for import duty & vat. Also means I have an easier UK route if I get any issues. Opted for the standard delivery (can't get my head around their upcharge for a courier), ordered Wednesday night online and arrived special delivery post on the Friday. Top service.
Can't get over how small it is
Got my EDIS, coil pack & VR sensor from good old flea bay and it came complete with all plugs & some loom tails.
Stripped it down a bit to get an idea on the sheilding
Also considered how to mount the trigger wheel. Didn't want one of the bolt in ones, partly for cost, but also told that it can make changing a fan belt into a mammoth task. Had a look at the rings sold by TW, and concluded that the ID was either too large or too small. then, saw an advert on Ebay that offered to do any size you wanted.
Quick mail & quote later, and I had a custom wheel. 48hr turnaround for the princely sum of £22.50 all in - Amazing.
Plug for the company
http://www.southernl...hernLasers.html top guy by the name of Ian, can't fault.
If anyones interested. ID 105mm OD 130mm
Will rebate the edge of the pulley to allow the ring to sit flush, and then lock into place with some screws drilled & tapped into the joint line. (might weld once the setting is confirmed)
Aware I need to put the MJ unit inside, and am probably going to pinch an idea from SolarB for the coil - Thanks SolarB
Not sure what he has used, but I have some Carbon Fibre sheet left over which I can sandwich together and cut to the correct size.
I also struggled a bit with the EDIS as I have the servo, extra wiring & relays etc, limited space left in the car and was running out of ideas.
Eventually......... The servo frame seemed an acceptable choice.
No chance of getting a drill in, but only a few bolts & a pin to remove
Line up for size & mark, checking to miss the bolts on the rear
Drill through & insert some rivnuts
Re fit to car and Robert's your Mothers Brother :)
Have a couple of cap head screws to make that a bit neater.
Positioned near the main fuse box & loom for the power and tacho feeds. One run arouund the front, past the coils to the VR, and one under the scuttle and into the cab for the MJ unit.
Finally, a quick trip to Maplins for some shielded cable and a couple of components for a Tacho driver (quid as opposed to £9). Haven't tested it yet obviously but my interpretation of the assembly with the Maplins part codes. (found after a search on a VW forum but cannot re find the link to acknowledge) is shown below.
If anyone knows that what I have shown below is incorrect, please advise and I will update or remove it.
That's where I'm up to today, hopefully I will have access to a lathe next weekend, (my pal sold his when he moved but the guy who bought it will let us use it) and I can get on with the carbon bracket in the evenings in the garage.
As always, comments welcome
Thanks for stopping by
Regards
Steve
Edited by stevede, 25 February 2012 - 05:33 PM.
