Daughter Zoe's Mini - Yeah Right!
723 replies to this topic
#421 chippy2710
chippy2710
  • 38 posts
Posted 03 October 2010 - 06:13 PM
Just read all 28 pages talk about putting in the effort and getting the results. Lovely.
#422 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 05 October 2010 - 06:04 PM
Thanks once again for the kind comments chaps.
It's been a little while since I have posted an update. Lots of other things going on including driving the mini.
Some time back, I showed a picture of some spotlamps I had bought. I needed to get some brackets but was finding it difficult to get what I wanted.
I mailed a couple of TMF'ers who kindly sent me some drawings and pictures of theirs (thank you), so I had something to work from.
At the weekend, I dropped by my pals place and whilst he was doing some fabrication work, and played around with some stainless bar.
Lots of space to work
Made up a template using some ali welding rod.
Bar was a bit tough for bending on a vice, so I found this!
I made a "first" attempt as a template!! Honest!
And then bent some more bar as a pair
Cut some plate to act as the support for the lamp
Tacked it, and the tested for level etc.
Before handing over to the master for a bit of quality TIG welding.
Cut some support plates to go behind the front panel
Now just need some cleaning up and final trimming before fitting.
Hopefully I'll get that done over this coming weekend when I'll update with some more pictures.
Thanks for looking
Regards
Steve
#423 mighty mini jack
mighty mini jack
    Mighty Before a Pint
  • 5,095 posts
Posted 05 October 2010 - 06:16 PM
Very tidy indeed, nice work guys.
#424 carboy001
carboy001
  • 1,065 posts
Posted 05 October 2010 - 07:52 PM
Good work Steve, looking forward to seeing them all on :shifty:
#425 danrock101
danrock101
  • 2,478 posts
Posted 05 October 2010 - 08:10 PM
Just read this from start to finish, took me nearly 2 hours. Makes me want to hurry up and get a project, what an inspiration!
#426 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 08 October 2010 - 03:47 PM
Bit more of an update on the lights.
Been off work today (long weekend) and took the opportunity of some decent weather to get the lamps on.
I re- tested the fit on the brackets and they needed a little bit of tweaking
Bit of levelling, some back plates marked and drilled up and some mounting holes drilled in the bars.
I can't tell you how tough the bar was to drill through. After burning out some bits (even using lube), I bought some ultra tough 6mm bits and they seemed to do the trick.
An extra check on level & position before finally going for it and drilling the bodywork.
Not perfectly matched, but you'll never tell with the lamps on.
First lamp
Couple more
And last but not least...........
Think I may need to do something with the number plate.
Just need to get them wired up now, and get some caps for the bolt heads to keep them nice and neat.
The original wire route is through the mounting bolt but I think that looks untidy so I'll drill some holes in the back of the shells and run the cable through a gromet.
More pictures to come once wired up and working.
Thanks for looking
Regards
Steve
#427 Timty
Timty
  • 848 posts
  • Local Club: S.U.N.M.C.
Posted 08 October 2010 - 04:05 PM
WOW! there great i love big rally lights, great job as usual.
#428 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 10 October 2010 - 08:13 AM
Wasn't sure of I'd done the right thing putting them on at first, but they are growing on me.
Got them all wired up and played around with the aim.
Didn't realise until I wired them but 2 have 130w bulbs in them, other 2 have mere 100w.
Went for a test drive and nearly blinded myself from the reflection off a roadsign.............. Need a bit more tweaking on the aim!!
Need to get on with the grille now.
Regards
Steve
#429 carboy001
carboy001
  • 1,065 posts
Posted 10 October 2010 - 08:21 AM
They look immense Steve! Job well done :D
Do I spy a Passat Coupe behind?
Also a little side note; I think I may have secured a loom for mine :P
#430 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 10 October 2010 - 08:27 AM
Cheers Chris.
Yes the new Passat arrived last week out of the blue. Still getting to grips with all the gadgets.
Good news on the loom, let me know when you need a lift.
Regards
Steve
#431 chrisandsarah
chrisandsarah
  • 746 posts
Posted 10 October 2010 - 10:22 AM
Cant say i like the lights - but the rest of the car is frikin lovely!
#432 reallybig
reallybig
  • 613 posts
Posted 10 October 2010 - 10:25 AM
wish i'd been able to do that myself to my mini, had to pay a garage a fair few £'s
#433 mk3cortina
mk3cortina
  • 677 posts
Posted 10 October 2010 - 11:21 AM
its funny how ive just read this page today where you have made up some lamp brackets like that, ive just today made some up myself. looking great!
#434 JGunn
JGunn
  • 37 posts
  • Local Club: None
Posted 10 October 2010 - 04:46 PM
Hi Stevede, thanks for your comment. ive just looked through your whole project, im liking the use of leds, also your roof lining looks amazing! Is that material quite stretchy? Mine had no give in it at all, hence the creases I have.
Now for the even wierder bit, while reading your project, I though I had seen your car before. The first giveaway was the light sunken into the bootlid and the leds in the c pillars sealed it! It turns out that we met at Stanford Hall, I dont know if you remember but i came over asking about arches and spacers etc.
The car looks really good, liking the lights on the front. I know what you mean about being blinded by road signs, i get that in my landrover.
Also fair play to you doing it all outside!
Jgunn
#435 shellspeed
shellspeed
  • 233 posts
Posted 12 October 2010 - 01:21 PM
You will have people getting up thinking its dawn when you put those on - luv it mate >_<
