Advise Fitting 13x7 Wheels
Posted 21 May 2009 - 12:05 PM
I have searched through the forum but unable to find a topic which covers the problem i have.
I know that in order to fit 13x7 i neeed to cut away some of the front of the wheel arch but mine rub behind the wheel as well. ive attached pic if it helps.
I just wanted to confirm that its normal when fitting these wheels that i will need to cut behind and infront of the wheel so it can turn without rubbing?
Thanks in advance.
Posted 21 May 2009 - 12:26 PM
edit: http://www.minisport...KAD1012230.html
Edited by newdawn1st, 21 May 2009 - 12:34 PM.
Posted 21 May 2009 - 12:33 PM
Posted 21 May 2009 - 06:59 PM
Posted 21 May 2009 - 07:04 PM
Posted 21 May 2009 - 07:07 PM
Posted 22 May 2009 - 09:39 AM
ive had 2 clubmans where i have had to trim bits of the a panel once done i've never had to change the rack just use the standard one never rubsMy mate had to trim a bit off his a-panels to get full lock if I remember right
Posted 22 May 2009 - 09:57 AM
Posted 27 May 2009 - 05:56 PM
Edited by toy231, 27 May 2009 - 05:57 PM.
Posted 27 May 2009 - 06:06 PM
firstly your mini WILL require some metal cutting away from the front panel and/or wing area to stop the tyre fouling the bodywork.contact simon at minispares and ask for the template you will require,dont forget TMF plus members qualify for discount.once the metal has been removed dont forget to roll the edge back,appy some rust preventer and colour finish.if your car has been lowered then the wheel will also foul the a-panel on lock.
to maximise your options i would fit hi-los all round along with fully adjustable suspension,not really required but will help,also make sure the rest of your suspension components are up to the job
Edited by the.stroker, 27 May 2009 - 06:45 PM.
Posted 27 May 2009 - 08:41 PM
Aye would agree - big wheels do need the geometry setting up accuratly to get the best out of italong with fully adjustable suspension
