I have a 1968 Mini matic. Everything is completely original My problem is that whenever it rains and being in Melbourne during non-summer months that's pretty regularly....anyway, when it rains Lesley will hold out for a bit, depending on the ferocity of the rain and direction, before loosing power, coughing and gradually slowing to a halt and turning off. Once off he wont start for a while. I can prolong driving in the rain by keeping my distance from cars in front because i guess I avoid all the additional fine water particles that they throw up.
I'm not sure whether this is an inherent problem with all original Mini's or specific for my case. My guess is that the rain gets in under the distributor cap and messes with all the electronics, since the distributor sits at the front just behind the grill.
I have tried to engineer a solution but the best I can come up with was to put heat wrap around each leads connection to the distributor cap or to see if there was a membrane which would allow air but not water through, but haven't had much luck with suppliers yet.
So I guess I just wanted to see if anyone has a better idea and also to check whether my diagnosis is correct.
Any help would be greatly appreciated.
Thank you.
Edited by srbmini, 19 May 2009 - 07:09 AM.
