After finishing my fiber filler job on my wing to scuttle gap yesterday, filling the holes in the filler with p38 and a a nice final sand with 120...I thought I had made a flawless repair. Could not feel the edges where it blended to metal (filler is going on a stripped and etch primed metal surface) no obvious imperfections....When I put a thin primer coat on top (etch primer) the edges jumped out, a small ridge showed up, and small pin holes....
So the question is do I need to go back and re-sand? the entire vehicle is going to be sprayed first in a hi build primer before the color coat (cellulose) and am wondering having never used this before, what kind of imperfections will it hide? It is ment to do this right, blend small imperfections out? Just would like a bit of clarification as I am spending alot of time (3 weeks now every night, and weekends...) trying to get the body perfect and would hate to go off my assumtion that it will be fine and have to fix it later....Thanks alot guys!
-Christian
Edited by Element_01303, 13 May 2009 - 08:27 AM.
