I have done a search and can't really find my answers.
I have a F/G front to spray and a bootlid - do the same principles and materials of spraying metal apply to fibreglass?
I'm using 2k for the body
Thank you in advance for your replies!
Icey
Posted 11 May 2009 - 10:25 AM
Posted 11 May 2009 - 10:28 AM
Posted 11 May 2009 - 08:13 PM
Yeah just key the fibre glass off with some 800 then use normal 2k primer & paint.Dont use acid etch primer as it eats the fibreglass. Other than that exactly the same proceedures apply. Key it well, degrease and paint
Paul
Posted 11 May 2009 - 08:22 PM
Edited by Tomf, 11 May 2009 - 08:23 PM.
Posted 11 May 2009 - 08:37 PM
I have sprayed several fibreglass front ends, wheel arches, motorbike fairings etc & have never had any concerns using the method I put earlier. It's all in the prep.I dont agree with the above answeres, use a plastic primer first (its like a clear primer, put this on as a dust coat, then paint as normal over that)
When my front end was painted this wasnt done and the paint soon came away from the fiberglass in a grazed sort of effect...
And my front end was preped as with normal metal, then given a final rough up with 800, all the paint on the metal is still in top condition, but everything that went on the fiberglass went bed...
I got the advise to use the clear plastic primer from both the top painters on the forum and three local paint shops.
Posted 11 May 2009 - 08:54 PM
Posted 11 May 2009 - 09:01 PM
Maybe we should agree to disagree but I have been spraying for over 15 years & have never had any of my paint come of fibre glass panels !!!I dissagree, speak to ant paint shop and they will tell you that when spraying large fiberglass panels you need to do more than you would compair to painting metal.
For small things like wheel arches and bike fairing they dont really flex much atall, but with mini front end there is alot of movment that is put through it unless you have it secured with about 50 bolts so it doesnt move!
If using a mini with a glass front end yes you migh get away with it if you drive the car like a 90 year old, but anything other than that after time the paint will come away over time.
Nothing to do with the prep, otherwise in my case the paint would have come away from the metal panels. And when i re-painted my boot using the plastic primer iv not had a single problem since then.
Posted 12 May 2009 - 06:37 AM
Posted 12 May 2009 - 07:50 AM
Posted 12 May 2009 - 08:18 AM
Posted 12 May 2009 - 08:53 AM
Posted 12 May 2009 - 12:47 PM
Posted 12 May 2009 - 01:35 PM
Posted 12 May 2009 - 02:44 PM
Paul
Posted 12 May 2009 - 03:05 PM
