The Rise And Fall Of Sir Reginald!
#121
Posted 10 August 2009 - 11:47 AM
looks like you'll have to put both on!
#122
Posted 10 August 2009 - 03:20 PM
Decided to get a new backplate for the rear brakes on the drivers side and a new cylinder too - seems easier than tarting up rusty bits
#123
Posted 10 August 2009 - 03:42 PM
I have one in storage, but its got surface rust due to it not having any coating. Although Por-15/Rustoleum will probably cure this
#124
Posted 10 August 2009 - 03:47 PM
#125
Posted 10 August 2009 - 04:44 PM
Wish i could be of some help
#126
Posted 10 August 2009 - 04:48 PM
#127
Posted 10 August 2009 - 05:22 PM
#128
Posted 15 August 2009 - 10:08 PM
** Drivers side Drive shaft stripped.
** Hub cleaned and painted.
** Disc refaced and painted drive flange.
** Stone guard cleaned + painted.
** New CV boot (all need replacing)
Going to nip down to Halfords tomorrow and get some new Pads, The ball joints aren't looking to happy but i think they'll be okay with a Thick shim removed and a thin one put in. They were so loose that i undid them with mole grips!
Talk tomorrow!
#129
Posted 17 August 2009 - 08:02 PM
And cut out the offending section of shock mount - nearly gave up when i opened it up to see Rust inside:lol:, but luckily it's just crusty surface rust and will clean up just fine
New metal soon
#130
Posted 27 August 2009 - 09:36 AM
Roof rack on :
Exhaust system now complete, made up of:
RC40 Twin box system - RC40 link pipe - Cooper Freeflow Manifold
Made up my stereo wiring earlier in the week too, soldered connectons - need some heatshrink:
Going to get the manifold on today and put the Gear selector roll pins in - Need a fixing kit ifor the rest of the system.
#131
Posted 27 August 2009 - 01:23 PM
Roll pins were a different matter - What a pain! they're both in now but boy! did they take some hammering in!! Seems all the hard work is getting it going and then they'll suddenly fly in.
good news is - They're on now and I could finally find out if i had all gears selectable - which i do! The change feels quite tight too which makes a nice change from the sloppiness we're used to!
Rest of the day will be spent under sealing after I've grabbed some luncheon!
Good times, And first Startup is looming
#132
Posted 27 August 2009 - 03:00 PM
#133
Posted 27 August 2009 - 09:36 PM
Liberated the correct colour wires from an old loom (apart from the yellow - this is to replace the yellow and white wires used for the ballast ignition) and Tinned the bare ends ready for soldering - also swapped the large Spade crimp from the brown inertia loom and re-crimped it onto the red/white for the piggyback solenoid. there's a few more browns i haven't pictured The blue/brown Is also on the ring crimp but is hiding behind the brown in the picture!
I will be soldering it up to the main loom tomorrow, and heat shrinking the joints.
Hopefully picking up my HS4 carb next week that's had the 'Vizard' modifications done to it.
#134
Posted 28 August 2009 - 10:30 AM
I'm jealous of the rat look
#135
Posted 28 August 2009 - 11:00 AM
