A little messing about today, I've decided to rebuild the brake master-cylinder I have, so while I wait for the parts to arrive I set about sanding, scrubbing and degreasing. Now it's etch primed.
Then I decided to whip a front wheel off and see what condition things are in. Bottom arm bushes are toast, but the rest of it appears okay and the underside of the panels is in fine shape, amen.
Cooper S 7.5 setup, barely used really, discs are fine, calipers fine, pads fine (I suspect I should replace these pads, they're barely used but are now a decade old,.. what say you?)
I may give calipers a layer of silver paint since they haven't rusted yet, and I want to replace the front hoses too.
Just out of interest I thought I'd chuck a wheel on to see if they really do fit. These are 10" rostyle wheels, with the correct offset to fit over the 7.5" disc setup archless. They fit with about 2-3mm space between the caliper and rim, tight,.. but it fits. Very happy about that.
Edited by Retro_10s, 01 October 2022 - 03:28 PM.
