Last night A very good friend of mine dropped off some parts i'd agreed to 'relieve' him of:
1x RC40 1"7/8 Twin box system. In as new condition. Really looking forward to fitting this, should be nice and quiet but with a nice rumble.
And a 'Minits' Water heated Inlet for my Hs4 carb, in great condition:
Went down to a local engineering firm today that do a lot of Minis engines etc and they've agreed to do the David Vizard modifactions on the Carburettor for me, which will involve:
* Knife edging the throttle disc.
* Butterfly shaft shaved, counter sunk and profiled to an aerofoil between the screw heads.
* Leading edges of the Piston chamfered to the carb bore.
With this work done on the carb I can expect to see around a 20+% increase in the flow capability of the carb
Next things on the plate are getting hold of a battery to check the leccies over, and buying some CV boots and front brake pads. The MOT will be done on the 12" set-up before i plonk the Cooper S set-up on at a later date.
