Took my Mini in for an MOT yesterday at a pukka station, never gonna make that mistake again! The bloke was a complete moany *melon*
Here's the List (Mostly all rear subframe)
Page 1
Front passenger seat cannot be secured in the upright position (fair enough, that can be sorted just by bending the hook back in place!)
Steering column top bearing excessively worn
Rear sub-frame corroded and seriously weakened
Nearside front (floor) subframe mounting prescribed area is excessively corroded
Offside front (floor) subframe mounting prescribed area is excessively corroded
Offside front (inner wing) subframe mounting prescribed area is excessively corroded
Nearside rear (floor) subframe mounting prescribed area is excessively corroded
Nearside rear (panel) subframe mounting prescribed area is excessively corroded
Offside rear (panel) subframe mounting prescribed area is excessively corroded
Page 2
Offside rear (inner valence) subframe mounting prescribed area is excessively corroded
Nearside front suspension has excessive play in a upper suspension ball joint **DANGEROUS**
Offside front suspension has excessive play in a upper suspension ball joint **DANGEROUS**
Exhaust has major leak of exhaust gases (Which the station supposedly sorted 2 weeks ago!!)
Exhaust engine idle speed too high
Nearside steering gaiter has split
Offside steering rack gaitor split
Offside front wheel bearing feels rough when rotated
Offside rear parking brake recording little or no effort **DANGEROUS**
Advisories...
N/S and O/S subframe attatchment rubber mountings deteriorated but not excessive
Nearside rear radius arm has slight play in a pin bearing
N/S and O/S tyres worn close to legal limit
Both front inner wings and sills corroded
Slight roughness in nearside front wheel beaings.
I was gutted. I knew it would fail on something but i've never known a vehicle to "fail" on so many points! I think this tester just got to the point of nit-picking every tiny floor he saw on the lil' car. "WHITE ROOF REFLECTS TOO MUCH LIGHT INTO ON-COMING TRAFFIC!!!"
Last year...She failed on 1 (ONE) item, which was a blowing exhaust. Took her to an ole' backstreet garage then.
So i'm in a bit of a dilemma. A lot of the stuff on the list can be easily sorted, is it just a case of buying a new rear subframe or do you think she has met the end of her day? Can't believe after failing on all this she drives like shes still on rails, still a pocket rocket! Guess everything wrong with her is under the skin
Should I just give up on the Mini scene? It's cost me an arm and a leg and need to start being sensible, but i'm gonna miss the fun and attention
A very sad Lewis
Edited by Lews_mini, 05 May 2009 - 03:30 PM.
