Shuddering When Moving Off
Posted 05 May 2009 - 08:52 AM
i will be ready to move off, i bring the clutch up and there is a shuddering, ony for a second, which also happens in second gear aswell, but not the rest (as far as i can tell). the closest thing i can think to compare it to is those yellow raised lines they sometimes have near speed bumps, to make you slow down, kind of that thump thump thump vibration through the car. hope this makes sense!
does this sound like the clutch needs adjusted?
thanks!
Posted 05 May 2009 - 10:40 AM
check the steady bushes and mounts and see whats what bud.
Posted 05 May 2009 - 10:43 AM
Paul
Posted 05 May 2009 - 10:48 AM
Posted 05 May 2009 - 10:50 AM
giving a vibration through the car similiar to the one you described
hope that makes sence
Posted 05 May 2009 - 10:54 AM
Posted 05 May 2009 - 06:16 PM
oh and what type of clutch would an 85 austin 998 mini have? i dont know if it needs adjusted?
Posted 05 May 2009 - 06:19 PM
i had a look and all the mounts/steady bars look fine. the clutch seems to be slipping a bit, and the pedal feels a little bit spongy. i think i need to bleed it?
You can try adjusting it, though it sounds like something more involved.
Just go to a good motor factor and they'll be able to supply a clutch plate. Should be pre verto Id have thought
Paul
Posted 05 May 2009 - 06:36 PM
oh just remembered that i remember the clutch made a "shloshing" sound sometimes when it was depressed and lifter?
Edited by finch661, 05 May 2009 - 06:42 PM.
Posted 05 May 2009 - 06:43 PM
If the clutch control arm is about 6" long its pre verto, 2" long its verto
Paul
Posted 05 May 2009 - 06:51 PM
Posted 05 May 2009 - 09:57 PM
Posted 05 May 2009 - 10:02 PM
But if its still doing it after about five minutes of driving then it sounds like a release bearing to me or possible oil contamination.
Posted 06 May 2009 - 08:37 AM
i will bleed tonight and see if that makes a difference!
Posted 06 May 2009 - 08:49 AM
Try wedging down the pedal for a day if you can, and check frequently to see if the reservoir under the bonnet needs topping up. This can sometimes make air move to the top of the system and be replaced with fluid and can at least make it feel better until you replace whatever needs replacing. Also, you can watch out to see if there are any leaks obvious in it!
