How Much Work Is Involved To Convert From Lhd To Rhd ?
10 replies to this topic
#1 Zacherius
Zacherius
  • 525 posts
  • Local Club: M4MINIS
Posted 03 May 2009 - 09:42 PM
How much work is needed to convert a Cooper Left Hand Drive to be Right Hand Drive ???
#2 captainjack15
captainjack15
  • 3,925 posts
Posted 03 May 2009 - 09:45 PM
Why would you want to?? :S Surely you could just drive it over here LHD??
#3 Zacherius
Zacherius
  • 525 posts
Posted 03 May 2009 - 09:53 PM
True, but if its not TOO much work, i'd rather change it. Still just thinking at options at mo.
( my father in law knows the lady selling it and can get it cheap. or she's actually got two others ( all convertible ) that may deserve a look )
#4 captainjack15
captainjack15
  • 3,925 posts
Posted 03 May 2009 - 09:56 PM
I can't help you with that, but cheap hey!! :(
#5 Zacherius
Zacherius
  • 525 posts
Posted 03 May 2009 - 10:00 PM
........... maybe I should have said cheap..ish
#6 mab01uk
mab01uk
  • 12,412 posts
Posted 03 May 2009 - 11:00 PM
The Mini is one of the simplest cars to convert especially of course the early Minis with the centre speedo dash! You will need a RH drive steering rack but most other parts just swap sides and the holes are already there for steering column, etc.. If you have a wooden dash this will also need to be replaced and the brake servo/ pedal linkage is different I think, again on early Minis both the brake and clutch master cylinders just swapped sides. The windscreen wipers are also easy to convert with grommets in the unused holes on the scuttle.
#7 cagy
cagy
  • 892 posts
Posted 04 May 2009 - 04:35 AM
you will need new pedals, new steering rack, new clock housing as you can't convert it over (i've a rhd 3 pod if you want to swap as i need a 3 pod left hand :( ) And being as it's from left to right there will be no problem with the servo, all the work can b carried out in a weekend and i have done it before, oh and you'll need new headlights the master cylinders you just put on the other side replace the pipes with shorter ones, you'll need a clock in miles (got one aswell from an advantage) it's not really hard work the only pain is the steering rack but all the work can be done in a weekend if all the parts are there.
Craig
ps.
I've converted from RHD to LHD which is harder than from LHD to RHD
#8 kez_19
kez_19
  • 946 posts
Posted 04 May 2009 - 05:11 AM
why do you need to change the pedals??? they are in the same place and set up i have a LHD and i cant see any difference between the pedals maybe its a small difference
michael
#9 cagy
cagy
  • 892 posts
Posted 04 May 2009 - 07:56 AM
it's the shape of the pedals, and the throttle is bolted on the right and not screwed as on the left.
Craig
#10 rickyo
rickyo
    Just On Tickover
  • 5 posts
Posted 07 August 2010 - 06:23 PM
Craig
If you do change the steering to RHD and your Mini has a power brake booster, would you be interested in selling the LHD parts?
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 07 August 2010 - 08:49 PM
A LHD clutch pedal in a RHD car ends up being quite a long way under the heater.
