"project Cosworth" - Ford Sierra Cosworth 4x4
1057 replies to this topic
#916 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 11 December 2014 - 06:50 PM
She is now legal........ if only the pedal box wasnt in pieces I could be driving her now  :D
Hang on, ive forgot to put the 'Mini 850' badge on the back! I must remember to do that!
They joy of being tax exempt. I wish I knew what that felt like.
#917 domdee
domdee
  • 1,183 posts
Posted 11 December 2014 - 06:51 PM
Another thing, did you have to take it for a fancy test before mot? And how easy was it to change the log book?
#918 kmol468
kmol468
  • 441 posts
Posted 13 December 2014 - 10:52 PM
The car still feels like a mini to drive, just one with really heavy steering.
Baldspeed, where about a do you usually drive then?? I'll keep an eye out for you.
I've got the pedal box sorted.... The master cylinders were in good working order. It was actually down to the length of the rod on the master cylinder being too long and not allowing the fluid to return to the reservoir!!
Despite being a complete off the shelf item, which should have worked, it didn't.
2AF8E93B-0094-49E0-BAF1-DA52F52DECE0_zps
It's not much to look at, but I put the new Wilwood master cylinders in and bled the brakes.
And yes those mounting bolts and banjo bolts are a ******* to do up. A spanners life was sacrificed and cut down and ground off to allow for streamlined access!!
So tomorrow is the day.... I'm going out for a drive... Once the frost clears from the roads!
#919 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 14 December 2014 - 12:50 AM
Hoon it!
Safely of course!
Edited by RossKnight, 14 December 2014 - 12:51 AM.
#920 kmol468
kmol468
  • 441 posts
Posted 14 December 2014 - 09:01 PM
I got the 850 badge fitted
5DA9E6FC-EA23-4591-AF9F-E61CFB767325_zps
It looks pretty standard and I like it.
So I started it up this morning to go out in it only to be plagued by it firing on 2 cylinders.
2 and 3 were receiving a spark, so we diagnosed it down to a faulty coil pack.
After spending time trying to find one on a Sunday we finally fitted another to find that it hadn't cured the problem.
Another hour later a wire was found in the loom broken from its pin.
7BDAAC1A-DCA3-41E4-8CDF-642A63746327_zps
Problem fixed we set out for a drive.....
Bloody hell it's quick, it goes through gears very quickly and pulls like a train. Footage will be coming shortly.
It wasn't reading revs correctly so that needs sorted and it was only registering 1.0bar of boost.
So I've got a couple of things to sort, along with getting it tracked, but it's bloody quick!
One thing is, to test it properly I need to put it on the track. On the road you just starting running out of space!!
Edited by kmol468, 14 December 2014 - 09:03 PM.
#921 RooBoonix
RooBoonix
  • 1,224 posts
Posted 14 December 2014 - 10:42 PM
Looking forward to the footage!
#922 kmol468
kmol468
  • 441 posts
Posted 14 December 2014 - 11:33 PM
#923 RooBoonix
RooBoonix
  • 1,224 posts
Posted 15 December 2014 - 12:45 AM
Mental! Loving that mate just the little niggly bits to sort out now
#924 jpw1275
jpw1275
  • 2,803 posts
Posted 15 December 2014 - 06:27 AM
Looks fantastic....... I wonder if it would fit through a mcdonalds drive threw ?
Cheers j
#925 Baldspeed Racing
Baldspeed Racing
  • 1,191 posts
Posted 15 December 2014 - 07:46 AM
I live in Southam mate so pop to Banbury every so often, my mini isn't sorted yet so drive my daily Mk3 Golf Wagon ;)
#926 1293gt
1293gt
  • 322 posts
  • Local Club: nonw
Posted 15 December 2014 - 09:21 PM
I'm not sure I'd be fooled by a Mini 850 badge sat behind a 15 foot wide Mini.....!!!
#927 kmol468
kmol468
  • 441 posts
Posted 15 December 2014 - 10:32 PM
Baldspeed, I'll keep an eye out for a mk3 wagon as there can't be too many of those about!
As for fitting it through a drive through, they wouldn't be able to hear my order due to a) the exhaust and b) shouting through Perspex! Lol
I think it was 6ft 2" wide but yes, I agree. I wouldn't trust the badge either!
I've got a long list of refinements to do one of which is to stop the boot from opening, the other is to fix the oil leak from the front diff seal! (It's typical that the only seal I didn't replace bloody leaks)
Another thing is to get some 0-60 times and acceleration graphs! I was gutted that I forgot my phone which has a g meter/speedo/data logger app on!
Edited by kmol468, 15 December 2014 - 10:34 PM.
#928 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 December 2014 - 11:05 PM
:lol:
#929 mr cooke
mr cooke
  • 278 posts
  • Local Club: Any
Posted 16 December 2014 - 08:28 PM
Love it , what does it handle like
#930 kmol468
kmol468
  • 441 posts
Posted 22 December 2014 - 08:48 PM
It doesnt handle too badly, although it isnt properly aligned so i wasnt pushing it hard into corners or anything.
Although there does seem to be quite a transfer of weight upon acceleration, you can feel the nose pick up and you can see that in the video.
Ill get the niggles out the way and hopefully put it down the pod on the first run what ya brung day of the year.
Posting might be alittle sporadic as all the little jobs arent exactly picture pleasing, but i will do my best to keep people up to date.
*****And shameless plug i know - if anyone has a spare standard rear view mirror, then get in touch, as I dont know where ive put mine!*****
Edited by kmol468, 22 December 2014 - 08:54 PM.
