Yay at last they fit!!
"project Cosworth" - Ford Sierra Cosworth 4x4
#766
Posted 01 September 2014 - 10:06 PM
#767
Posted 01 September 2014 - 10:09 PM
Although there will be a long list of fiddily jobs to get though!
#768
Posted 01 September 2014 - 10:15 PM
Fiddly jobs are great but annoying, you never remember them all and what parts you need until after you click place order!
Cam.
#769
Posted 02 September 2014 - 09:11 AM
Sure is wiiiiiiiddddddeeeee! going to have to watch parking that at the shops!
Looking good though fella.
#770
Posted 03 September 2014 - 07:21 PM
This thing is wide lol but coll as fooooook Gona be a total beast
#771
Posted 03 September 2014 - 08:16 PM
But she didn't drive. :-(
I think the clutch arm needs adjusted.
#772
Posted 06 September 2014 - 08:14 PM
#773
Posted 06 September 2014 - 08:48 PM
The clutch has a 0.7 master cylinder on the pedal box, with flexi -3 hose going to a land rover 2a slave cylinder. Which then actuates a threaded metal rod which pushes the original clutch arm. We have put a return spring on it but it seems after bleeding the system, the clutch has the normal amount of travel on it. After a couple of pushes the travel becomes less and less until there's about an 1" of movement before it comes solid.
If anyone has encountered the same please let me know how to resolve this. HELP!
I don't know if a seal in the master cylinder has popped and it's pressurising fluid and not letting it return... Sighs
Also the hydraulic handbrake needs replumbing.... The rear brake is still leaking .....
but on a positive note my friend and I have a working set of car ramps installed in our workshop and ready to use.
#774
Posted 06 September 2014 - 08:59 PM
Might be similar? Not sure. But good luck!
Cam.
#775
Posted 06 September 2014 - 09:06 PM
#776
Posted 06 September 2014 - 09:19 PM
I honestly can't wait to see videos of this running!
Cam.
#777
Posted 06 September 2014 - 09:26 PM
I was trying to think of a comparable car but I can't think of any..... It's going to be an animal.
#778
Posted 07 September 2014 - 07:32 AM
But having never been in one i wouldnt no.
Power to weight must be comparable though?
#779
Posted 07 September 2014 - 09:10 AM
nice build mate, just read it all . great job
as for the pedal going hard, check the adjustment on the master cylinder rod, it sounds like the master cylinder piston is preloaded and not releasing pressure when the pedal is released.
cool car I love your vision, and I think it looks great just the way you have built it.
#780
Posted 08 September 2014 - 08:27 PM
It must be millimetres off not engaging, as it just goes in with the engine off but when you start it the gears don't engage and just rocks the car slightly forward when trying to engage first.
So technically it has travelled now under its own steam! Lol
I think adjust the actuating rod and it will be there!
First proper video of the drive will be posted as soon as it happens.
