"project Cosworth" - Ford Sierra Cosworth 4x4
1057 replies to this topic
#691 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 11 June 2014 - 10:05 AM
Now I'm all moist! lol
#692 kmol468
kmol468
  • 441 posts
Posted 18 June 2014 - 07:22 PM
4419A786-FF9C-4201-9BCA-6F146B4B7160_zps
Epic brake fail!
These are the rear brakes and despite being assured they fit, they don't.
I do concede that the rear cosworth brakes are quite large and vented but I thought they might have squeezed in.
If anyone has any experiences with fitting brakes under 13" wheels then please feel free to contribute.
I phoned up a well respected brake manufacturer and I literally got laughed at. They said that they wouldn't be able to help me!
#693 Summerill2
Summerill2
  • 68 posts
Posted 18 June 2014 - 07:25 PM
When my old man fitted an atlas rear axle to his dolomite sprint in the late 80's, he used ford calipers of some nature, but had to grind a wad out of the caliper and could only run half worn pads.. He ran the original 13inch sprint wheels though!
#694 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 June 2014 - 07:27 PM
Just amazing!
Congratulations you have it running. Sounds like you are in high spirits in the video!
Ben
#695 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 18 June 2014 - 07:28 PM
Oh, don't do that!!!
Calipers are a certain thickness for a very important reason!
#696 Summerill2
Summerill2
  • 68 posts
Posted 18 June 2014 - 07:35 PM
It's a forest rally car and never had a problem!
#697 matty...
matty...
  • 605 posts
  • Local Club: Turbominis
Posted 18 June 2014 - 09:37 PM
Awesome project, looks like such a good quality build!
As for brakes, are you wanting to use OEM brakes or are you happy to go after market? Wilwood do a massive selection of calipers,
but they would more than likely require custom carriers. Owens fabrication do a Wilwood conversion kit to fit under 13" wheels, but that setup would probably be too much for the rear, but they may have some suggestions of a rear conversion too?
#698 kmol468
kmol468
  • 441 posts
Posted 18 June 2014 - 09:45 PM
I don't really mind if it's oem or aftermarket.
The only trouble being if I go too small with oem I think I will just fry them.
I'll check out Owen fabrication, cheers. I don't mind spending the extra if I know that they will work.
#699 albo
albo
  • 204 posts
Posted 18 June 2014 - 10:30 PM
how about sum wheel spacers,,might make your wheels stick out a bit tho,,,,, O_O
#700 SAL 821X
SAL 821X
  • 1,890 posts
Posted 19 June 2014 - 09:02 AM
Well the rims are already 2 foot wider than the body so I guess another 10mm won't make much difference.  :D
#701 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 19 June 2014 - 11:55 AM
Hard to tell from the photo how much extra clearance you need, moving the wheel weights could be a start. If it's only a couple of mm I'd say grind the calipers, but anything more than that is a bit risky.
Aftermarket calipers would be the ideal, and going slightly smaller won't cause you any problems as the car is already significantly lighter than the standard Ford.
#702 kmol468
kmol468
  • 441 posts
Posted 19 June 2014 - 12:15 PM
The calipers have already had load ground off them and they are touching on the sliders and bleed nipple.
Custom setup I think, as the sierra cosworth hubs have different caliper mounts (90mm spacing) to that of standard sierras!
#703 R1mini
R1mini
  • 1,387 posts
Posted 19 June 2014 - 07:28 PM
I use the unvented 253mm disc and calipers from the sierra disk braked model, under 13" minator wheels and they fit nicely. I would be surprised if the hub disk brake carriers were different between sierra cosworth and the normal disk braked sierra. I'm refering to the hub carriers and not the vented brake discs and calipers.
According to this post it a nut and bolt upgrade to use the vented disc setup on a solid disc sierra and therefore it follows you can do the reverse
http://passionford.c...scs-to-2wd.html
David
#704 Spud_133
Spud_133
    mmm potato and cheese....
  • 1,689 posts
  • Local Club: C&T Classics
Posted 20 June 2014 - 07:46 PM
I'm sure you can fit 13"s over the standard discs are fitted to the last sierras.
#705 R1mini
R1mini
  • 1,387 posts
Posted 20 June 2014 - 07:55 PM
They are different sizes depending on the model, the sierra cosworth has the biggest sierra brakes off them all
David
