Made the second fuel pump bracket from a piece of metal that I found laying about.
I decided to run the fuel lines down the passenger side of the car.
Lift pump supply with filter and swirl pot return both coming from the tank. I think I need to update those labels on the fuel tank.
Now the spaghetti of lines at the back of the car with everything in situ
And this is what I was left with of the 6an fuel hose at the end of the day, talk about cutting it close.
I was wondering, for those eagle eyed, you can see that the fuel pick up point is at the rear corners of the tank. This is fine due to the acceleration of the car but my fuel tank is slightly tilting forward and so would struggle to pick up fuel if just sat normally.
Do you think I should flip the fuel tank around so the pick up points are at the front of the car?? (After all I have a swirl pot to eliminate fuel surge)
