Have to ask ???? whats happened to the build ???? is it sill ongoing ??? can you give an update please ?????
"project Cosworth" - Ford Sierra Cosworth 4x4
#601
Posted 30 January 2014 - 03:22 PM
#602
Posted 30 January 2014 - 07:19 PM
When there is an update I'll post something with pictures and ultimately first start up videos.
#603
Posted 31 January 2014 - 06:03 PM
i hope the update is soon, i read the entire thing about a week ago and ive been dying to hear more since :)
#604
Posted 31 January 2014 - 06:47 PM
#605
Posted 01 February 2014 - 02:17 PM
guess we will all have to wait patiently then :)
#606
Posted 01 February 2014 - 04:30 PM
I cant wait to see this bouncing and popping down the road, Insane build mate
#607
Posted 14 February 2014 - 12:03 PM
This project is barmy!
#608
Posted 15 February 2014 - 09:25 PM
#609
Posted 23 February 2014 - 05:53 PM
seriously cool build, and some real good fabrication going on there!
#610
Posted 23 February 2014 - 06:04 PM
just read this great build !
#611
Posted 10 March 2014 - 06:51 PM
I had to rummage around to find things, as things are all over the place. I'm determined to get it started so spent an hour or so tinkering with the engine bay.
From a slightly different view
It shows the blue water hose connected at the front left of the engine disappearing around the cam belt and into the oil modine.
This was necessary as I'm not running a heater matrix. I'm effectively bypassing it, making sure the circulation of water is still flowing as per the original spec.
But rotating that water outlet on the thermostat was very stubborn. Sod's law will say that it will weep come engine start time.
I've got the small 8mm water turbo lines to plumb in via the turbo cooler and the swirl pot feeds to make. Then make and connect the header tank and the coolant system is sorted.
Edited by kmol468, 10 March 2014 - 06:53 PM.
#612
Posted 10 March 2014 - 06:56 PM
looking good!!! cant wait to see this finished!!
#613
Posted 11 March 2014 - 06:40 PM
Also got the engine bay fuel lines done. The rail supply and return with dry break connector.
Top line is the feed
The supply to the fuel pressure regulator with fuel pressure gauge fitted.
Return line to the bulk head
Also started on the layout of the fuel system at the back and got halfway through. I mounted one pump, and have the second to sort out.
Then I have the lines to run through the car.
#614
Posted 11 March 2014 - 07:05 PM
#615
Posted 11 March 2014 - 07:39 PM
this thing is going to be an animal can't wait for more progress, keep it up buddy !
