"project Cosworth" - Ford Sierra Cosworth 4x4
#46
Posted 23 July 2009 - 09:03 PM
#47
Posted 23 July 2009 - 09:24 PM
Although I'm thinking of making extra braces from the roll cage, going forward to help support things! That's the plan anyhow!
#48
Posted 23 July 2009 - 09:28 PM
#49
Posted 26 July 2009 - 03:43 PM
I have got rid of the complete ABS - the plan is to go back to basics with the brakes! Ive saved so much weight due to getting rid of the ABS ECU and all the wires and sensors associated with it! Here it is laid out on the grass...
Some people would say to keep it, but im going to be using 'LMCK' (the mini, pronounced lee-muck-uk) on the track and drag strip and there isnt really any call for it. The amount gained outweights the need for it!
Other things that have been taken out are the electric windows, central locking (which took up a sainsburys bag by itself!), electric mirrors, heated front windscreen (which had tonnes of wiring for!), heated rear screen, interior lights, door sensors, electrics for the heater, cig lighter, clock, electrical control box, bulb fault control unit (a box which tells you which bulb has broken!) front fog lights, rear washers, intermittent wipers, dash light dimmer. i must be missing things but you get the point!
While doing this I found out that the scuttle of the cosworth was held in place with cable ties and rubber matting! Once removed the scuttle practically fell out in my hands due to rust! I thought rust was just found on minis! but appartently other cars suffer aswell!
Abit more thinning...
All of the wires with red tape were removed......
the fuse box before ....
the fuse box after........
As you can see, theres abit of a difference, and once the loom is transplanted I will get a new fuseboard and keep it 'simple' with minimal wiring required. Im planning to have one loom for the engine, and one for the lights with bulk head connectors. However thats ages away yet, but I'm still thinking about it.
So the dreaded few days of work climaxed to see if with all the wiring removed it would start again...... I will let the videos do the talking.......
So now the wiring is practically sorted its time to remove it and get on with the grinding and the mechanical side of things! I mean surely it must all fit in.... where did I put the measuring tape!!!!????
However I wont be transferring the Power Steering, its too heavy/bulky and saps BHP from the engine. Anyway the original mini didnt come with it so why should I bother with it! Happy to hear peopels views on it though.
#50
Posted 26 July 2009 - 04:06 PM
I don't want to say too much about them, i'll leave that to the owners, but one has been about for a while, some of you might even know about it already, and its fitted with a 24v Cossie, though now its been fitted with 2 Turbo's. The others are still being built and both are running Cossie 2ltrs, one with a genuine RS500 lump! Both are RWD, ones auto the other manual!!. The 24v one should be out at MITP, and the other 2, fingers crossed, should be at the 2010 Mini Showdown, racing along side a mate of theirs in his little green mini.No real progress made just more thinning of the loom. Once it's sorted, I will show you the bags of wires!
V8cos: I don't suppose you have any information about them? Pictures, blogs, or websites even, I know it's a long shot, but it would be interesting to see how they shoe horned it in and what components they retained from the mini!
#51
Posted 26 July 2009 - 05:17 PM
#52
Posted 26 July 2009 - 08:55 PM
#53
Posted 26 July 2009 - 09:27 PM
#54
Posted 31 July 2009 - 04:23 AM
#55
Posted 31 July 2009 - 09:09 AM
#56
Posted 31 July 2009 - 04:31 PM
#57
Posted 01 August 2009 - 12:21 AM
#58
Posted 10 August 2009 - 06:19 PM
Removed all the wiring
Drained all the fluids
Removed the bumper, radiator, intercooler and anything that practically connects the block/gearbox to the car!
Next job is to just undo the engine cradle mounts and gearbox mounts and drop the whole unit complete. Then all I have to do is move it across the driveway and offer it up to the mini. Simple!
Hopefully at the weekend i will get to that stage and dig the angle grinder out!
#59
Posted 11 August 2009 - 02:49 PM
Dave.
#60
Posted 21 August 2009 - 09:27 PM
