"project Cosworth" - Ford Sierra Cosworth 4x4
1057 replies to this topic
#556 paul_s
paul_s
  • 415 posts
Posted 30 July 2013 - 12:11 PM
This. Is. Insane.
I've just read it through from start to finish, it sounds like it's been a hell of a slog but you're not far away now. And I know it'll be worth it once you've got it all done and dusted.
Normally I'm more of a fan of keeping minis standard but the sheer amount of love and engineering that's gone into it is going to make a blindingly fun, and fast, machine!
#557 kmol468
kmol468
  • 441 posts
Posted 31 July 2013 - 05:53 PM
I've been ordering some parts and I can't believe how expensive fuel filler hose is! I would recommend 'car builder solutions' for some.
Anyhow the point of no return
I think mounting it like i have has ruined the look of the rear end but needs must, as there's no way in hell I'm climbing in the back to fuel it.
Front perspex is in and silicon sealed front and back. I've pushed the perspex to the outside of the doors and fitted the front outside door seal. I've sealed the underside and I've expanded foamed either side of the perspex to hold it in place.
Hopefully the carbon door cards will be trimmed and fitted shortly.
#558 jpw1275
jpw1275
  • 2,803 posts
Posted 04 August 2013 - 07:48 PM
fantastic!!!!! not much else i can say buddy
cheers james
#559 kmol468
kmol468
  • 441 posts
Posted 10 August 2013 - 08:31 PM
One side done, which isn't too bad as I usually end up drilling holes just slightly off so the bolts don't line up!
The drivers side door doesn't fit that nicely but hopefully when the door card goes on it will pull it in and hold it.
Does anyone else have problems fitting fibreglass doors and perspex?
#560 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 10 August 2013 - 10:02 PM
They normally fit awfully!!:P. always takes a lot of work to fit them right.
#561 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 11 August 2013 - 10:34 AM
dude!! this looks epic!
#562 kmol468
kmol468
  • 441 posts
Posted 11 August 2013 - 06:54 PM
Been at it again today and got the other door card fitted.... But look at that lovely panel gap!
Also found a new way to fill up the gearbox
Sorted the ignition amplifiers
And fitted and cleaned the samco hosing, swirl pot, dump valve and surprisingly they went on with minimal fuss.
Dirty
Clean
#563 R1mini
R1mini
  • 1,387 posts
Posted 11 August 2013 - 07:17 PM
If you've got 300 plus horsepower you could put metal doors on, they are not that heavy
David
#564 ginsters
ginsters
  • 183 posts
Posted 11 August 2013 - 07:44 PM
stunning!
#565 MiniLandy
MiniLandy
  • 796 posts
  • Local Club: HAMOC
Posted 11 August 2013 - 08:03 PM
Coming together now chap, keep it up.
#566 mini=love
mini=love
  • 211 posts
Posted 11 August 2013 - 08:10 PM
I did the same with my old project, went a bit weight saving mad, but after fitting the fibreglass doors and getting a fit like yours, i was more than pissed off. They soon went in the bin after the first test drive. ill leave it for you to find out how good they are haha.
#567 kmol468
kmol468
  • 441 posts
Posted 11 August 2013 - 09:08 PM
Regarding the doors: I wanted fibreglass doors as I wanted the car as light as possible, but I would have thought people making them would have used a jig!! They weren't cheap copies so I thought they would be a straight swap.
Anyhow I'll get it running and see how badly the wind effects them. I suspect quite badly, but hey ho, I'm not going to loose sleep over it at the moment.
#568 hoody99
hoody99
  • 699 posts
Posted 11 August 2013 - 09:58 PM
Could you not just cut a wedge out the inside of the window frame then re glass it when in the right position ??
#569 tractor
tractor
  • 662 posts
Posted 11 August 2013 - 10:42 PM
Looking good mate,
You must be thinking of a test drive soon?
Trac
#570 Baldspeed Racing
Baldspeed Racing
  • 1,204 posts
Posted 12 August 2013 - 03:42 PM
This........I was going to say this
