"project Cosworth" - Ford Sierra Cosworth 4x4
1057 replies to this topic
#511 tractor
tractor
  • 662 posts
Posted 29 April 2013 - 09:07 PM
Just wondering what are you cleaning everything with? Everything's come up really nice, the block in particular looks awesome
Trac
#512 kmol468
kmol468
  • 441 posts
Posted 29 April 2013 - 09:14 PM
I just cleaned the block with wire wool and good old fashioned elbow grease.
I found that as the block was all uneven the wire wool did the job to get into all the nooks and crannies.
Although the block is painted silver and isn't just the block stripped back.
#513 tractor
tractor
  • 662 posts
Posted 29 April 2013 - 09:32 PM
O I see,looking good, I love this project, I've read it from start to finish now, it's gunna be fast that's for sure
Trac
#514 kmol468
kmol468
  • 441 posts
Posted 29 April 2013 - 09:36 PM
Hopefully it will be quick! 380bhp is what I'm aiming for!
Blimey that must have taken a while to read all the pages.
#515 tractor
tractor
  • 662 posts
Posted 29 April 2013 - 09:46 PM
360bhp is brilliant if you can get anywhere near 600 per tonne you'll leave everything standing
Best of luck to you and I'll be following with interest
Trac
#516 kmol468
kmol468
  • 441 posts
Posted 30 April 2013 - 08:48 PM
Can anyone tell me how I fix the head to the block when it's like this??(see earlier post)
The answer is to remove the rocker cover, all 10million bolts, scrape off the sealant around the half moon seals and be really pleased that I bought a re-useable rocker cover gasket.
Then fit head to block and then fit gasket, sealant and the 10 million bolts that hold the rocker cover on. I mean what happened to fixing it with just 2 bolts like the mini. Anyhow rant over and lesson learnt.
Managed to turn the engine the right way round and clean up pistons, fit uprated head gasket and fit the head. Is it me or its actually coming together....?
Those eagle eyed will spot the distributor blanked off ready for distributorless ignition.
Now it's ready for the tubular manifold, Swedish inlet plenum and the turbo.....hmmmm
#517 freshairmini
freshairmini
  • 1,718 posts
Posted 01 May 2013 - 11:12 AM
They prlly didnt use two bolts like the mini because, like the mini, it probably would seep oil everywhere!  ;D
#518 thelegg
thelegg
  • 608 posts
Posted 01 May 2013 - 11:40 PM
the 2 pulleys at the top are crying out to be red or blue :( i must say your doing a great job cleaning that engine :)
#519 kmol468
kmol468
  • 441 posts
Posted 02 May 2013 - 08:09 PM
Did abit more today... Cleaned the alternator and fitted the alloy pulley although sadly it is silver. Although the alternator bracket is red to make up for it.
Fitted a new crank positioning sensor and its RED alloy bracket
Went to fit my tubular exhaust manifold.... and the engine mount can't be fitted with it on! Grrrrrrrrrrrr.
If you look in the middle of the picture below you will see the hole that the mount is supposed to bolt into.... It's miles out.
It looks like I'm going to be using the standard crappy cast iron (weighs a tonne) manifold.
I'm gutted to say the least
#520 kmol468
kmol468
  • 441 posts
Posted 03 May 2013 - 06:14 PM
More cleaning
Before...
After......
#521 tractor
tractor
  • 662 posts
Posted 03 May 2013 - 09:24 PM
Looking good, is this more wire wool?
#522 kmol468
kmol468
  • 441 posts
Posted 03 May 2013 - 09:38 PM
No just a wire attachment in a drill for the main flat areas
#523 LTSwaby
LTSwaby
  • 48 posts
  • Local Club: Barnsley mini club
Posted 03 May 2013 - 10:00 PM
there was a clubby in mini magazine a while ago with a cozzie engine and running gear
#524 kmol468
kmol468
  • 441 posts
Posted 03 May 2013 - 10:18 PM
Swaby are you on about the yellow one? If so I believe that was a 2.9 litre n/a v6 engine rather than my 2.0 turbo version
#525 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 03 May 2013 - 10:31 PM
No there was a blue one. RWD cozzy YB lump. Looked the ********. Mini magazine:D
