"project Cosworth" - Ford Sierra Cosworth 4x4
1057 replies to this topic
#496 CobraV8
CobraV8
  • 991 posts
Posted 01 April 2013 - 03:15 AM
And.....l they lok awesome!
#497 minilee94
minilee94
  • 3,523 posts
Posted 01 April 2013 - 10:43 AM
Why the hell are the arches that wide ??
#498 freshairmini
freshairmini
  • 1,718 posts
Posted 01 April 2013 - 11:26 AM
Because of the engine and rear axle is a much wider track than a standard mini...
#499 josh.evans
josh.evans
  • 1,439 posts
Posted 01 April 2013 - 11:32 AM
Very nice.. keep it up looking forward to seeing this one!
#500 kmol468
kmol468
  • 441 posts
Posted 01 April 2013 - 06:33 PM
Blimey those arches are wide! It would be interesting to see that build thread.
Ive just just been cleaning, ordering and fitting random parts this weekend....
The bottom end now has arp bolts fitted.
#501 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 01 April 2013 - 09:46 PM
That link is for breadbox racing's build on 16v mini club. I think he broke it up in the end and didn't finish it. If I remember it has a pontiac V8 in the back.
It was taken over by a guy called Joltfreak but not a lot has been done since. Here is the link
http://www.16vminicl...ead.php?t=19090
#502 Archived4
Archived4
  • Archived
  • 822 posts
Posted 01 April 2013 - 10:37 PM
Love this. Also, with regards the rear and front track width, have you thought of a shortened rear beam? On passionford a guy with a rwd fezza has a beam which has had 2 or more inches chopped out the width of the beam. I will give you the link. Just an idea if you get smaller arches. Looks like a monster. Best of luck, Nathan
#503 minilee94
minilee94
  • 3,523 posts
Posted 06 April 2013 - 10:25 PM
Nar I know why there wide but they stick way past the wheels .im not putting you down by the way as I have checked this thread from day 1 and has been brilliant
#504 kmol468
kmol468
  • 441 posts
Posted 07 April 2013 - 04:24 PM
Cleaning the block takes ages...... But by the end of it, it looks better for it.
The new viton seals for the crank, front and rear, are fitted along with the auxiliary seal.
I just need for the block to dry properly then I can fit the sump seals and then big winged sump.
While the block was drying, I managed to finish off the cylinder head. Installed the half moon seals, gasket and sealant and tightened everything down. Also fitted the thermostat housing with new o-ring so it is literally ready to bolt down.
#505 thelegg
thelegg
  • 608 posts
Posted 09 April 2013 - 03:06 PM
Thats going to look so good when you lift up the bonnet :) what colour hoses n stuff are you going for ?
#506 kmol468
kmol468
  • 441 posts
Posted 09 April 2013 - 09:38 PM
All the pulleys are going to be red, along with all the aeroquip red/blue fittings, however hoses are going to be blue.
So I'm going with a red and blue theme!
#507 thelegg
thelegg
  • 608 posts
Posted 15 April 2013 - 11:27 AM
sounds awesome :) you going to continue that through out the whole car ?
#508 kmol468
kmol468
  • 441 posts
Posted 15 April 2013 - 02:07 PM
It's not going to be throughout the car as there is literally nothing going in the car. Just the pure basics, fuel tank, brake lines, seats and carbon door cards. Hopefully it won't rattle too much!
#509 tractor
tractor
  • 662 posts
Posted 29 April 2013 - 05:44 AM
What a monster, I'd love to see this in action when it's done
Following with interest
Trac
#510 kmol468
kmol468
  • 441 posts
Posted 29 April 2013 - 08:52 PM
It will get done its just a question of how long it will take....(as with all projects)
More pictures..
I've dug out the sump from the shed and fitted it after getting some aeroquip fittings welded to things. Also managed to fit some pulleys despite putting the auxiliary pulley on backwards to begin with! (Matt Damon)
Note the homemade blanking bracket on the right hand side which replaced the really heavy power steering bracket. Also the breather and oil return line had bee fitted for aeroquip fittings.
Prizes to those who can spot how many aeroquip fittings are in the last picture! Lol
I just hope the sump seals as there's no gasket in between them!
