"project Cosworth" - Ford Sierra Cosworth 4x4
1057 replies to this topic
#421 kmol468
kmol468
  • 441 posts
Posted 17 June 2012 - 04:59 PM
Well I have been out working on it this weekend and I have taken a couple of pictures for you all. Theres nothing that different, but all the random holes have been welded up and painted over. Ive also sealed all the seams underneath and then its ready for waxoyling. Ive been internet ordering so hopefully things should be turning up shortly.
Ive split the engine, gearbox, diffs, drive shafts and will be working on rebuilding everything.
Although it was abit worrying that nearly all the suspension bushes were split and the engine mounts were broken aswell!!
Anyway heres a few pictures: My apologies theres no pictures at the end of the day as ended up applying sealant without gloves!
#422 kmol468
kmol468
  • 441 posts
Posted 21 July 2012 - 10:01 PM
Been doing abit more today. I've got the whole underside seam sealed, doors fitted, boot fitted and front end fitted.
The front end has been dzus fastened, but it is touching both turrets and strutbrace on the underside. I will have to keep an eye on it rubbing. It was my intention to do the same with the boot, but all the holes were there so thought just hinge it and dig out the old lock. Im probably going to ditch the standard number plate light as it weighs a tonne and just find something more subtle.
Also manage to fit in the petrol tank mounts and seats so that everything is ready for paint.
So 10 points to the person who points out the most shocking panel gap! Lol
Also managed to fill up the old filler neck hole as I intend to fill through the rear window.
I now need to order all the seals and fit the perspex, then it's water tight.
#423 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 21 July 2012 - 10:05 PM
Keep the updates coming, I admire this project and would love it to be on a TMF stand
#424 Brams96
Brams96
  • 2,308 posts
Posted 22 July 2012 - 03:38 PM
Not sure whether you mean the passenger door or the boot ;-)
#425 andy pandy
andy pandy
  • 270 posts
Posted 22 July 2012 - 03:46 PM
id say the door
#426 thelegg
thelegg
  • 608 posts
Posted 25 July 2012 - 09:45 PM
gotta be the door
#427 kmol468
kmol468
  • 441 posts
Posted 03 August 2012 - 05:21 PM
I've been cleaning today, it's practically the last main component that needs cleaning apart from the engine and drive shafts
Before:
After
I might be tempted to lacquer it.
Although I have noticed a chunk missing out of the cradle, would this indicate that the drive shaft has jumped out although it is on the drivers side!
I might see about getting it welded up tomorrow
#428 kmol468
kmol468
  • 441 posts
Posted 07 August 2012 - 06:21 PM
Bits have arrived in the post today, mainly a stack system that I managed to pick up on the cheap!
Although my intention was to use my apexi gauges with the original ford speedo but I don't know now.
I'm liking the stack system as it is compact but I do like my apexi gauges..... Hmmmm what do people think?
Oh on a side note if people know of any good painters willing to paint my mini pm me with their details as people who I have approached locally don't seem to want the business!
#429 TopCatCustom
TopCatCustom
    Previously known as C4NN0N.
  • 1,134 posts
Posted 08 August 2012 - 09:15 AM
Stack on a budget..??!! Really! Use the original ones and sell me the Stack ;D
#430 Brams96
Brams96
  • 2,308 posts
Posted 08 August 2012 - 05:10 PM
What advantages does the Stack have over conventional guages? If your going for the more classic look then the gauges but otherwise the Stack would look good.
#431 Spud_133
Spud_133
    mmm potato and cheese....
  • 1,689 posts
  • Local Club: C&T Classics
Posted 08 August 2012 - 05:25 PM
I think the Stack gauges, but I love the look of Stack gauges!
#432 kmol468
kmol468
  • 441 posts
Posted 08 August 2012 - 06:47 PM
The stack system is more compact really and does all the fuel pressure, oil pressure and temperature, water temperature. It can do everything apart from boost and exhaust gas temperature.
It's also easier to mount one item rather than the original ford item with all the gauges. The stack also does warning lights which are configurable between certain perimeters.
I think I might use the stack with the boost and egt gauge. I just have to see if the stack system works!
#433 Brams96
Brams96
  • 2,308 posts
Posted 08 August 2012 - 07:30 PM
Hey, can I just ask what is the overall width of your mini now? (to the outside of the wheels)
Edited by Brams96, 08 August 2012 - 07:31 PM.
#434 kmol468
kmol468
  • 441 posts
Posted 08 August 2012 - 07:46 PM
With the 9" wide wheels its 6ft 2" or 183cm!
#435 jonosavage
jonosavage
    Starting My Mini Up
  • 1 posts
Posted 09 August 2012 - 12:39 AM
This is a great project, really very well done all round! Look forward to seeing it complete :)
