"project Cosworth" - Ford Sierra Cosworth 4x4
#256
Posted 13 September 2010 - 07:08 PM
#257
Posted 13 September 2010 - 07:52 PM
It was really interesting to see what went wrong along the way and how you've fixed it, the car sort of morphed with all that welding and cutting and welding and cutting!
One of my fav projects of allll time
#258
Posted 14 September 2010 - 11:17 AM
With the shortening of the original floor plan have you made any changes to steering arm angles for your Ackerman Principle? Something to consider....
I know the mini wheelbase is 2040 but what is the wheeltrack now on yours, looks to be around 1800???
Now is going to be the hard work for you, best of luck with it, cant wait to see it running.
#259
Posted 14 September 2010 - 11:33 AM
#260
Posted 14 September 2010 - 01:03 PM
sweet your going for the archesless look i recon you will get away with itIve got it back now, so all I have to do is finish it off, where did I put my spanners??
#261
Posted 18 September 2010 - 04:55 PM
Having pratted around with things today I took a quick measurement and from centre to centre the trackwidth is 1580, what that means in terms of technical calculations I dont know as I thought it was a relation with steering arms and rear diffs, but I think I will get it running and moving under its own steam and them see about getting it set up.I know the mini wheelbase is 2040 but what is the wheeltrack now on yours, looks to be around 1800???
Fitted the bias pedal box today and had a quick layout of both seats and fuel tank, and all I can say is that its going to be tight. I couldnt even get the seat to fit with side mounts fitted! So back to more head scratching and I think I might need some remote reservoirs fitted to the pedal box me thinks!
As for mocking up the front end I didnt get round to it (maybe tomorrow) but I think it might be the same as I have a huge intercooler that practically take ups the complete front end, lets just hope the flip front will accommodate it. (im sure it will)
All the pedals need levelling and adjusting but I just got it in to see how she looks
I started taking the sound deadening off of the roof but then realised how annoying that stuff is and went inside to get something to eat! lol
#262
Posted 28 September 2010 - 03:28 PM
any updates
Edited by tony13, 28 September 2010 - 03:30 PM.
#263
Posted 28 September 2010 - 08:03 PM
Not a juicy update but I've managed to source and install a working area, thankyou Mr B, as I was working in the rain with no workbench! I've also managed to work out how the front end is going to be mounted and ive got some steel for the seat mounts.
All I've got to do is cut the shapes and get welding. Although when the front end gets fitted the rad and intercooler will be a good picture!
I've also got some more parts on order which should help with the pedal box!
#264
Posted 28 September 2010 - 08:14 PM
#265
Posted 29 September 2010 - 05:54 AM
Having pratted around with things today I took a quick measurement and from centre to centre the trackwidth is 1580, what that means in terms of technical calculations I dont know as I thought it was a relation with steering arms and rear diffs,I know the mini wheelbase is 2040 but what is the wheeltrack now on yours, looks to be around 1800???
Your quite right it is, sorry I didnt word my previous reply very well. they were supposed to be two different subjects - oops.....
Anyhoo, I thought I would do you the service of drawing up the Ackermans for you do with what you please, I had a spare 5 mins anyway:
#266
Posted 29 September 2010 - 01:32 PM
In all serious, in what relation do the above drawings presented portray for the layout of the mini cosworth? Will this effect handling etc? Interesting to learn..
#267
Posted 29 September 2010 - 03:05 PM
cptkirk; but what does this all mean?!!
Well ideally the point of the triangle should meet level with the rear axle. If it doesnt then it is said to have a negative effect on the handling. As to the highlighted discrepancy I dont know how much of a negative effect it would have. Although im pretty sure that once it starts getting out of line, ie the back getting unstable then its pretty much going to spin due to the short wheel base. Lets just hope the 60/40 of power will help to combat this.
CptKirk: Are there any 'rules' as to how much it is out by and the effect it has on the vehicle??
The problem being is that there's so much to think about I think I would go crazy if everything had to be considered. While I do acknowledge it might be 'interesting' to drive as a result of the width to length ratio, im going on the basis that a 4wd mini with around 370bhp will more than make up for the effect that it will have on the handling.
Edited by kmol468, 29 September 2010 - 03:14 PM.
#268
Posted 29 September 2010 - 03:14 PM
You've obviously got some skill to build this!
#269
Posted 29 September 2010 - 03:30 PM
It's going to be an exciting drive however you look at it!
I would like to claim all credit for this, but someones done the hard work for me, I just have to finish it off now! lol
#270
Posted 29 September 2010 - 03:34 PM
It looks amazing, can i ask how much its all cost?
Chris
